Question about DeLonghi PAC C120 Portable Air Conditioner
Triangle light is flashing, and unit will not reset,or turn on
How to reset service warning lights
Turn key to position I
Then press and hold odometer button
Turn key to II and wait for the triangle to start flashing before releasing it whilst still flashing.
It makes a beep sound and the message disappears..
May 13, 2014 | 2006 Volvo XC90
Yellow triangle with ! in the middle popped up on dashboard what does that mean
It's the ESP warning light, You may have a ESP button on the dash which you can push to reset it, Otherwise try having the car idling in neutral and turn the steering wheel fully left then right the back to middle, This should reset the light, if it comes back you will need to get the car plugged into a diagnostic scanner to find the issue.
Mar 04, 2012 | 2001 Mercedes-Benz C-Class
Volvo c30 How do I reset the maintenance remider message.
1. turn ignition to I
2. depress and hold trip button
3. turn ignition to II(while still holding trip button)
4. in about 5-7 seconds warning light(yellow triangle) begins to flash
5. release trip button WHEN yellow triangle is flashing(it flashes 5 times, if you wait for it to stop flashing, it will NOT reset), turn ignition off
Mar 02, 2011 | 2008 Volvo C30
What does the two small lights on the back indicate? One of them looks like a battery symbol and the other one looks like a pair of triangles on a teeter todder.
The triangle shapped one is the symbol for bluetooth. It should light up/flash when you have the unit paired to a phone that is turned on
Feb 04, 2011 | Jabra BT2080 (BT 2080) for Sony Ericsson...
Volvo S60 2001 warning light, Engine System Service Required comes on. Just had a tune up at 78,000 but not @ Volvo. How do I turn off the light.
  1. Turn the igntion to position I
  2. Press and Hold the Trip Odometer Reset Button
  3. Turn the ignition to position II and hold until the triangle with the ! mark inside flashes (yellow)
  4. Turn ignition off, then back on to confirm reset accepted.
Jul 04, 2009 | 2004 Volvo S60
How to reset service timer on dash
hold in your trip reset, continue to hold, put in key and turn to position 2, wait about 10 seconds, your triangle light in the center of your instrument panel will flash 3 times, after the 3rd flash, release the trip reset. then cycle your key off and back on. your service light should be off. good luck and god bless!
May 07, 2009 | 2002 Volvo S60
Orange light is flashing
Unplug the power cord for 10 seconds
Feb 05, 2009 | HP LaserJet 1020 Printer
Clearing service message on dash
Turn the ignition to position 1 Push and hold trip reset while holding. Turn to position 2 hold trip reset till the service light flashes 3 times and then release. You should hear a beep to let you know it is reset. It might take you 2 times sometimes. If you have the message in the text window the little triangle in the center of the speedo assy. will flash. Also another trick to help you is when the milage returns the light should be reset.
Jan 22, 2009 | 2004 Volvo S60
Routine service reminder
with the ignition off press and hold the left hand button on the instrument cluster, turn the ignition to 2. (so that the ignition lights are on) still holding the button until the yellow triangle flashes, this is about 8 seconds. when this happens release the button and turn ignition off again. this resets the service light (SRL)
Benjo
Aug 26, 2008 | 2006 Volvo XC90
DeLonghi PAC C120 Portable Air Conditioner Logo
63 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
