Question about Nikon D5100 Digital Camera with 1855mm lens
How can i change the dpi in a Nikon D5100. in the menu? thank you.
3 Suggested Answers
Rider On Way
  • 1679 Answers
SOURCE: Hi My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? please help me, it's an emergency. Thanks!
This should be helpful.
Turn the lens to Manual mode (moving to M). Twist the very tip of the lens till it unlocks.
If you twist the lens on the end far enough on the end to the right you will find it "locks". This is what is causing the screeching sound,, it's locked and can't auto focus. Twist the very end to the left till it releases. This fixed it for me.
Regards,
Sean
Posted on Jun 09, 2013
  • 357 Answers
SOURCE: Hi My Nikon D5100 camera giving a sin of Autoexposure error. Contact a Nikon authorized representative message after it's drooped from my tripod on the deck floor (Wooden Floor). The Nikon55-300mm
There is no way to really answer this question as the camera was dropped. If it was dropped with the lens, then the problem could be either in the body or the lens (or both). If you have another lens try it and see if you get the same result. Otherwise you are probably going to have to take it to the shop or send it to Nikon
Nikon D5100 dark screen on live view mode
Open your appuatue set your ISO to 200 or 1600 what ever it needs
Feb 20, 2014 | Nikon D5100 Digital Camera
Jun 09, 2013 | Nikon D5100 Digital Camera
How to format sd card in nikon d5100
Press the MENU button. Press cursor-left. Use cursor-up/down to select the wrench icon. Press cursor-right, then use cursor-up/down to select the "Format" command.
Apr 21, 2013 | Nikon D5100 Digital Camera
What are the raw settings for d5100
You set it for raw in the shooting menu then clik onImage quality then toggle right and set Jpeg or NEF RAW good luck I suggest JPEG fine for you RAW takes all your space up unless you are pro and know what you are doing
Jan 15, 2013 | Nikon D5100 Digital Camera
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.
The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
Nov 27, 2012 | Polaroid Wireless Performance Battery Grip...
Nikon D5100 Autoexposure error when camer is first turned on
Hi I'm having the same problem!!!
My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? I tried few does not work, please help me, it's an emergency. Thanks!
Aug 28, 2012 | Nikon D5100 Digital SLR Camera With...
Nikon D5100 vs Nikon D3200
They both take superb pictures. The D3200 is slightly easier to learn how to use, while the D5100 is easier to use once you learn it. That is, the D3200's menus will guide you through all its settings, while with the D5100 you can change those settings with less work once you learn the proper buttons to push. The D3200 has a higher resolution, but even the D5100 will take photos that can be enlarged to 8x10 and larger.
I suggest you go to a good camera store and try them both out. See which one better fits your hands. You don't want to buy a camera based on specs, or other people's opinions. You want a camera that best works for YOU. Having said that, the D3200 is probably a better first SLR. However, try them both out and choose the one that's better for YOU.
May 19, 2012 | Nikon D5100 Digital Camera with 1855mm...
Can I use Quantaray AF 28-90mm f/3.5-5.6 in a NIKON D5100? Thanks.
Quantaray makes lenses with a variety of mounts for a variety of cameras. A lens with a Sony mount, for example, will not fit onto a Nikon camera. Assuming the lens has a Nikon mount, it will fit on the D5100. However, the D5100 requires the lens to have an autofocus motor. If the lens does not have such a motor then it will not autofocus. It will still work fine as a manual focus lens.
Jun 19, 2011 | Quantaray AF 28-90mm f/3.5-5.6 Lens for...
Nikon D5100 Digital Camera with 1855mm lens Logo
20 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
