Question about Greenworks 1600 PSI 1.3 GPM Electric Pressure Washer 51152
Greenworks 51152 Power Washer Leaking Wand
The connection between the wand and handle is leaking. I have taken the cover off, but the wand will not come apart to replace any damaged parts. Is there a way to replace the o-ring or do I have to replace the entire wand?
    Sergeant:
  • 406 Answers
Yes the o ring is replaceable try using a 1/4 inch id o-ring .
Posted on Aug 05, 2013
Need wand for greenworks 23 bpm pressure washer, where can I get one?
Lowes and northern tool both sell replacement wands
Dec 29, 2017 | Garden
Hi, water intake leaking on greenworks 1600 ele. sprayer thanks! its brand new!
Send it back - if you are in the UK the SOG act applies if in the US then Tough
Oct 23, 2015 | Greenworks 1600 PSI 1.3 GPM Electric...
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
Pressure wand is leaking at the out let end, and pump has a small surge when setting at a idle
Sounds like water is leaking past the shutoff valve on the wand. Check your owners manual parts diagram to see if there is a washer or o-ring to replace.
Apr 16, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
How to fix 12POE-150 power washer leaking gun wand
There are no parts available for the inside of the guns. All you can do is replace the gun.
see parts in link.
http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
May 01, 2014 | FAIP 1500 PSI Electric Power Washer
Help, my power washer is LEAKING!!!
was water left in the washer for the winter and it froze ?ice expands and brake stuff like that
May 20, 2012 | General Garden
My Snap-On 2000 PSI pressure washer is leaking through the trigger handle. I have no pressure coming out of the wand but the motor runs.
The fitting for the trigger is cracked. It happened to mine because I did not make sure the wand and hose was drained before winter came. The water left in the wand expanded and cracked the trigger housing. The problem is that the trigger piece is easily replaceable, but it is not available. Alltrade makes you buy the complete wand.
May 12, 2011 | Garden
Leaking at valve handle for broadcast
This happens a lot. Sometimes it's just the hose connection to the wand. If that appears to be the leaking spot, remove the band clamp, take off the hose, and cut off the last 1" of the rubber hose so you get a fresh end. Push the freshly cut end onto the wand, and tighten the band clamp. Did that fix it? If not, you'll need to replace the wand, but they aren't too costly. You'll find some on this page . Good luck! Please rate my solution if helpful, thanks.
Jul 17, 2010 | Northstar ATV Spot Sprayer 26 Gallon, 2.2...
Greenworks 1600 PSI 1.3 GPM Electric Pressure Washer 51152 Logo
560 people viewed this question
Top Greenworks Garden Experts
richie46
Josh Van Nostrand
Steve
Steve
Are you a Greenworks Garden Expert? Answer questions, earn points and help others
