Question about Compaq Computers & Internet
Moniter keeps shutting off - Compaq Computers & Internet
  • Compaq Master
  • 27,725 Answers
Is it just the monitor and not the entire computer shutting off ??
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Posted on Aug 01, 2013
Fixya solutions:: my question is about my Hewlett Packard model p6-2003W desktop blue light on ucp and moniter going to sleep and shutting off when I reboot or shut off power they both come on and I a
The problem can be correct in the control panel power options..
select hig performance as the preferred plan,
click change plan settings
change both sleep options to never>>
this is caused by a corrupted display settings in the registery and needs to be reformatted or restored using the factory restore disc to fix the problem. the above solution will work just remember to put your system to sleep manually and turn of your monitor.
Dec 29, 2012 | HEWLETT-PACKARD Computers & Internet
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Aoc 2216Vw monitor black outs
try to check with the monitor selftest if the monitor self test passes, the issue is with the video card. to check your video card: try to connect the monitor to integrated port and check out so that we could find if the problem is with the video card.
Jun 10, 2009 | Sony Computers & Internet
Dell moniter, brightness adjustment keeps coming on
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
Jun 06, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Magic Bright
Problem is made by switches which are bad quality, you have to take your monitor to the nearest samsung service center or if you want you can change this switches by yourself. You can find them in conrad stores named phap3363 and art.nr: 700310 - 62
Dec 11, 2007 | Samsung Syncmaster 17" 720N Monitor
Will not close down
These monitors go into a standby just incase you are only restarting the PC.
To turn it off properly, hit the power button on the monitor before Windows has completely turned the computer off.
IE: tell Windows to shutdown, when you see the blue screen telling you Windows is shutting down, turn it off then.
Hope that helps
Oct 20, 2007 | Acer AL1715 17" LCD Monitor
Computers & Internet Logo
14 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
