Question about Motorola Mobility Motoluxe 1GB Black XT615 Unlocked Phone 3G 900/2100
I have a red cross sign beside the battery symbol on the left ,i cannot get wi fi
    New Friend:
Mep cod 0 left eazy solustion
Posted on Aug 01, 2013
Undefined
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
Where is pound sign
Most keyboards touch the symbol key bottom left then select key
Oct 06, 2014 | Samsung Galaxy Fame GT-S6810P Smartphone -...
My Kindle is not picking up the wi fi signal what code do I need to put into it??
Try this:
  • Press the Home button, then press the Menu button.
  • Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  • Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  • Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  • Enter the name of the Wi-Fi network that you want to add.
  • Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  • Choose "submit." Kindle connects to the new Wi-Fi network.
  • If this doesn't work feel free to reply and I will try find another method. However, if it does please rate me. Thank you.
    PCHELPSTER007 from youtube
    Jul 06, 2011 | Computers & Internet
    How do you get the wi-fi on the ds
    To set up a Wi-Fi connection on your DS Lite you have to use a Wi-Fi enable DS game. Wi-Fi enable DS games have a Wi-Fi symbol on the front of the box it came in. Simply play the game and you should see options to set up a Wi-Fi connection.
    Apr 21, 2011 | Nintendo DS Lite Console
    Pandigital won't connect to wifi. went to a locaton that had free wifi, no password required and it won't connect
    On the top of the tablet is the Wi-Fi & Low Power Button.
    Make sure that it is "slid" to the left.
    1. Tap Wi-Fi settings to select and connect to a local wireless network.
    The device automatically scans and lists local Wi-Fi Networks found.
    A indicates secure networks that require login passwords to connect.
    2. Tap the desired network to which you want to connect.
    If your Wi-Fi broadcast is set as hidden, it won't be found by the auto
    scan. Tap Add Network -> enter the network name and key,
    -> tap Save.
    3. If the network is secure, tap in the password entry field to enter the
    Network Password.
    4. Tap Connect.
    5. Tap < to return to previous screens.
    The Wi-Fi symbol on the top of screens indicates the Wi-Fi is connected, otherwise no icon is displayed
    If you did all of the above, get a hold of Pandigital
    Feb 14, 2011 | Office Equipment & Supplies
    Just bought one from my freind ,how do i get the internet working on it
    iPod touch gets its internet from WiFi signal that it captures. If you don't have WiFi around you, you will not be able to connect to the internet.
    To see if there are available WiFi connections around you, here's what you gotta do:
    >on your iPod touch screen, go to Settings
    >once the Settings window opens, you'll see Wi-Fi next to Airplane Mode (from the top). If your current not connected to any WiFi signal, it should say not connected beside it.
    >tap on Wi-Fi and choose from the available networks on the list, but make sure that Wi-Fi is turned ON, first. If in case there's no WiFi signal around you, you still won't be able to browse the web.
    >tap on any network from the list. often times, WiFi signals are secured, which means you should know the password to be able to connect, otherwise, you'll still get nothing.
    you'll know that you're already connected when there's a check symbol on the left side of the network that you've just selected, and also, the WiFi symbol appears beside your carrier name.
    Once you're connected, just exit the Settings window and go to Safari to browse the web.
    For more iPod touch / iPhone tips, click here.
    Feb 26, 2010 | Apple iPod touch
    Unable to access the setup wizard screen after typing 192.168.0.1
    ok
    ifu have ethernet coonection check wetherney connection to your computer.
    if u have wi fi then connect your wi fi network then cherck.
    Mar 22, 2009 | NetGear DG834G Router
    Flashing red symbol like a bowl crossed out
    it means you have no back up battery installed to save time/date info. I know on the GL2 if you open the LCD screen there is another small plastic tab you can open and insert a relatively small battery. Do it and the icon will disappear. Otherwise its no big deal. If you dont need time/date stamps on your tapes then there is no need to install the battery unless you are just annoyed.
    Feb 22, 2008 | Canon GL2 Mini DV Digital Camcorder
    Motorola Mobility Motoluxe 1GB Black XT615 Unlocked Phone 3G 900/2100 Logo
    63 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
