Question about 3Com NBX 3102 IP Phone
Roll back phone software
I received a 3Com 3102 phone with R5.3.0 software on it but our system only has R5.0.25 software. How can I roll back the software on the phone? It is currently in a continuous reboot.
    Guru:
  • 57 Answers
Add the NBX's IP and mac address to phone. Also static it on the same subnet.
It will go through about three long reboots.
If it doesn't work change the NBX to anything but "ethernet only" and reboot it. Then reboot phone with the above settings.
Posted on Jan 14, 2012
    New Friend:
  • 3 Answers
The phone is in a continuous because it is trying to connect to the NBX. You need to make sure it is on the same network as the NBX. Also, within the NBX you need to make sure Auto-Discovery is enabled. You also need to check how many group 2 licenses you have, as this phone requires one to run on the NBX.
Posted on Jan 29, 2008
SOURCE:
How do i reset voicemail password on 3com 3120 phone?
On 5.0 and older software, Log into the NBX Phone system as administrator and click on "tab to it". Then click on the "security" tab under System Configuration. Click on "Reset User Password". Highlight the user you want to reset and then click "reset. The system will reset the password to the same as the extension number.
On 6.0 and later software, Log into the Phone system and go to "System Maintenance, Password Administration". Select "User Password" in the drop down menu and click "Go". Select the box on the left for the extension you want to reset and click on the "Reset Password" button at the top of the list. The system will reset the password to the same as the extension
Hope that helps!
Aug 02, 2014 | 3Com NBX 3102 IP Phone
3com 3102 not working
try 192.168.2.1 / 192.168.2.0 / 192.168.0.1
hope it works.
enjoy
Feb 15, 2008 | 3Com NBX 3102 IP Phone
Web page + 3102
You can't web to a 3102 phone, only the phone system. If you don't know what the IP address is on the phone system, you will have to get a serial cable (null modem cable) DB9 male to DB9 female and connect to the console 1 of the phone system. You will need a terminal emulator program and connect at 9600, 8, none and 1 for the settings. Type nbxIpConfig (case sensitive) and hit enter. The IP address will then be shown. If this is not what you were asking, please explain.
Feb 19, 2014 | 3Com NBX 3102 IP Phone
Reset 3com 3102
Hi Chirag,
On the web interface, use
1 Click System Maintenance > Purge Data.
2 Click Purge Database
This ll do fact reset.
HTH
-Karthik.
Oct 02, 2012 | 3Com NBX 3102 IP Phone
3Com 3102 phone dial tone but won't dial out
As long as someone hasn't been poking around in the phone system, this is a phone company issue. I have seen this many times and it has always been a carrier issue. Typically with PRI's or integrated access analog lines.
May 08, 2012 | 3Com NBX 3102 IP Phone
I want to block a number on 3com NBX100
are you using a PBX system ? you can block your number the same way you would with other phones. if you have to dial a number before you can get an outside line, the dial the code after,. usually *67
May 03, 2010 | 3Com NBX 3102 IP Phone
When someone call 3Com NBX 3102 IP Phone we cannot hear them talking, but they can hear us. I tried it on three 3Com systems and same thing happens. We get problems like these often and we are just...
If the phones are only 6-8 months old you should be calling 3Com. those phones have a 1 year warranty and once you register them they will help you troubleshoot and replace them if needed. Can you provide more detail? Do you have any network issues while this is happening? Does speakerphone work but the handset doesn't?
Apr 29, 2010 | 3Com NBX 3102 IP Phone
Cant connect additional 3102 to nbx. Please help!
3102 phones require group 2 licenses purchased from an authorized NBX reseller. if you don't have enough the system will not allow the phone to be discovered. You can check this unler the licenses tab while logged into the phone system as administrator.
Jun 25, 2009 | 3Com NBX 3102 IP Phone
3com NBX phone number of rings setting problem.
Delete the MAc Address from the system and delete the user account. Re add the phone.
Feb 12, 2009 | 3Com NBX 2102 IP Phone
3COM PHONE BLOCKING CALLS
You have to log into the system as Admin and enable CO COdes for the CLass of Service you are in. Its easy, at least the Admin should be able to do it.
Apr 11, 2008 | 3Com NBX 3102 IP Phone
3Com NBX 3102 IP Phone Logo
357 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
