Question about Wolfgang Puck Salt & Pepper Mill Set
Salt grinder does not work - Wolfgang Puck Salt & Pepper Mill Set
Salt and pepper grinders how to clean
warm soapy water, you can put some soapy water in the grinder, shaker and shake it vigorously to remove any pepper or salt that is stubborn, but hot water will dissolve the salt and loosen the pepper.
Sep 29, 2014 | Cuisinart Salt and Pepper Grinder,...
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Wolfgang puck bistro elite gravity spice mill
Go to this website: http://www.hsn.com/products/wolfgang-puck-bistro-spice-mill-with-peppercorns/7012934
and click on the Video under the grinder picture. I think this may be helpful
Feb 10, 2013 | Wolfgang Puck Bistro Elite Gravity Spice...
How to load peppercorns into trudeau 0716840
I found the following webpage on your grinder: www.shoptrudeau.com/v/vspfiles/images/instructions/0716840.pdf
Just in case the link doesn't work, it looks like the top (salt) part just pulls off the bottom, pepper grinder part. With the top off, there's a hole to pour the peppercorns into.
Jan 20, 2013 | Trudeau 0716840 Click Combo Pepper Mill...
My grinder will not turn on. The cup and lid are on lockThe light are on. When i press the start button it does not grind
The best case is that the contacts that turn the motor on are not working, maybe need cleaning. Someone would have to open up the grinder to check and correct that. The worst case would be that the rotor or field coil to the motor became fried. That happened to me when I tried to grind damp sea salt.
Jul 29, 2011 | Mr. Coffee 2.3 oz. Coffee Grinder - White
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
Wolfgang Puck Salt & Pepper Mill Set Logo
97 people viewed this question
Top Wolfgang Puck Home Experts
john h
Tom Chichester
Are you a Wolfgang Puck Home Expert? Answer questions, earn points and help others
