Question about Kenwood Audio Players & Recorders
I have a Kenwood KR-V7070 receiver. My problem is that I cant get the rear channels to work. I have tried everything. I have output on the front and the subwoofer. I know that the speakers are all working so that couldn't be the problem. Any idea what to do. I appreciate suggestions greatly.
4 Suggested Answers
  • 17 Answers
SOURCE: Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Posted on Jan 01, 2008
dunnbiker
  • 8546 Answers
SOURCE: i need help trying to
Manuals help. Read them. Nothing in your receiver is actually a multichannel source so you'll be needing to understand the external sources that originate that kind of programming. Manuals.
Here's one...
http://www.retrevo.com/support/Kenwood-VR-309-Receivers-manual/id/480dj195/t/2/
Try the other manufacturers' support sites for your unidentified gear, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
'Large' is not literal in the context of Bass Management. It refers to the ability of a given speaker to handle REAL bass. Yes = Large, No = Small. 'Small' redirects bass from that speaker channel to the sub.
Web search concepts like bass management, speaker placement, multichannel sound, digital audio, etc.
Posted on Sep 05, 2011
  • 3 Answers
SOURCE: Yesterday, I connected two speakers to my Kenwood
Always always always unplug the electrical cord before you change any speaker connections. One tiny ground-fault can fry the circuitry.
Posted on Dec 08, 2011
How do I connect the TV to the receiver. An RCA TV Model #LED58G45RQ TO Receiver KENWOOD Model# KR-A3060 For Audio
If your RCA TV has left and right audio outputs on the rear, connect them to corresponding inputs on the rear of your Kenwood receiver.
Jan 09, 2017 | RCA Audio Players & Recorders
How to hook up a pioneer 7 band gr 470 equalizer to a Kenwood kr-v6030 receiver
Connect one pair of RCA cables between the receiver and equalizer. Connect one pair of cables to the pre-amp output channels on the receiver and the other end of the cable to the left and right channel inputs on the equalizer. You will usually find these channels on the rear of the equalizer.
May 09, 2016 | Pioneer Audio Players & Recorders
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
KENWOOD KR-V8030 SPECS
I have had this exact Receiver and this is taken right from the specs. in the manual, "120 watts per channel RMS" at 8 ohms - this is in Stereo mode (2 speakers) only". When surround sound is used, "75 watts RMS for Front and Center speakers and 15 watts RMS for rear (surround) speakers. From experience, the Stereo only mode is definitely stronger/louder than when switching to Surround. Most newer receivers are the same wattage regardless of mode.
Feb 19, 2012 | Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Yesterday, I connected two speakers to my Kenwood KR-V7070 Receiver and it worked fine but today I can't hear anything coming out of the speakers. I may have pressed a wrong button on the remote. Also,...
Tell us some details about the speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V7070-Receivers-manual/id/479bh947/t/2/
Familiarize yourself with the controls. Understand every indicator on the front. There may be a clue there. Turn the volume to a medium or low level before changing any settings or you may be in for a BIG (and costly) surprise when you find the one that was in the wrong position.
Let
Mar 02, 2011 | Kenwood Audio Players & Recorders
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
I have an old Kenwood receiver that does not power up anymore. Not even the red standby light glows. I have power to the unit but that is it. I have checked the fuses on the inside but after that I am no...
If the voltage was 110, the polarity should not have made a difference. In all probability, the input power transformer has an open primary. This can happen with a power surge or just because of age. If you have an Ohmmeter, with the unit unplugged, measure across the 2 input pins for the main transformer. It should read about 3 ohms or less. If it reads infinity, it is open and must be replaced.
Keep us posted,
Dan
Mar 12, 2009 | Kenwood Audio Players & Recorders
Rear speakers won't play sound.
check on the front of the unit for a speaker selector- make sure A & B is selected
Feb 04, 2009 | Kenwood VR-307 Receiver
138 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
