Question about Dell Dimension 4600 PC Desktop
Hard Drive I replaced the factory Hard drive from Dell because they said my old hard drive was bad. Dell also mailed me a burned CD that said Dimension 4600 on it. Once I got the hard drive installed. I turned on my computer and I didn't know what CD to put in. I got a message that said "Primary Drive 0 found" Then I entered the Dimension 4600 CD and pressed F1 and it said do I want to boot from a hard disk or CD Rom, I chose CD and then I had a list of 5 choices, I tried a couple of them and nothing seemed to work. Window's won't even come on. Please help!
  • 3 more comments
  • drew2682 Aug 31, 2007
    What CD do I enter? The windows cd or the dimension 4600 cd that they sent me. I kept getting an error message for the IDE drive.
    The dell guy told me to put the windows xp cd in. When do I put the windows xp cd in then?
    If I remember right it didn't seem like it did. I had to hit F1 after the cd rom light went off, then I chose like option 2- boot from Cd rom. Then it gave me like 5 or 6 choses. They were like diagnostic checks? I didn't know what option to pick.
    Ok I am not by the computer that is having the problem. I am at work and it is at home. Can you just tell me what steps I should take from the moment right before I turn my computer on. I will print it out and work on it when I get home. Thanks.
    Thanks, I will let you know, one more question, the other night it wanted me to insert a floppy disk into drive A: That was already formatted, what does this mean? How do I get a formatted disk.
  • 78 Answers
Put the CD in your CD Drive and shut off the pc. Then start it up again making sure the CD is still in the drive. You will then be asked if you want to boot from CD. Press any key to confirm this (it might skip asking you if it detects that your hard-drive is already blank) Then you want to let it run its install routine. Im not sure what options it will give you but the ones you are looking for is FULL install.
Posted on Aug 31, 2007
  • 3 more comments
  • Anonymous Aug 31, 2007
    The Dimension 4600 CD
    Im not sure what is on your Dimension 4600 CD, im assuming its the restoer cd.
    This should be put in first.
    When you do have it in and restart the pc does it look like its doing anything?
    Ok, do everything I said earlier but put the XP CD in instead. It looks like the cd Dell sent you is a driver only cd.
    If you get stuck, let me know what's on screen and Il guide you.
    M
    Ok,
    Here is a link to a website that has a step by step guide and pictures:
    http://www.windowsreinstall.com/winxphom...
    When you get to the bit about deleting a partition if you dont see that screen then it means you dont already have a partition, so you just press enter on the only option it will give you. Then continue following the guide.
    Let me know how you get on
    Not sure why it asked for that, it might have been trying to make a bott disk or a driver disk!!
    Without a working system you wont be able to make a formatted disk.
    If you have access to a pc, get any floppy you dont need and insert it. then go to My computer and right click on drive A: then just click format.
SOURCE:
My Toshiba p300 laptop has suddenly lost its operating system. It says pxe rom "operating system not found media test failure" Any suggestions battery is 2 1/2 years old running windows vista....
I am glad to HELP YOU!
Usually this error appears when your booting media [HDD] is damaged or your CMOS settings are wrong.
This issue is caused by
1. an incorrect setting in CMOS setup
or
2. a bad boot device [a bad hard disk].
WHAT TO DO:
# verify that your boot options are correctly set in CMOS setup. I'd suggest to set the CD/DVD as your first boot device and the hard drive as the second boot device.
# if your CMOS setup has an option to boot from the LAN, then give up this option by disabling it.
# if you changed any CMOS settings - SAVE AND EXIT from CMOS setup and reboot the machine.
If this does not resolve the issue try to reset the CMOS/BIOS values to the default settings > SAVE AND EXIT > REBOOT.
GOOD LUCK!
... and don't forget to RATE, please...
Apr 20, 2011 | Toshiba Satellite Pro P300 Notebook
I have a Dell Inspirion 8600. XP SP3 w/all of the latest MS updates. Got keyboard error message, rebooted and got blue screen related to keyboard error. rebooted, reset Boot menu to Dell factory default....
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 04, 2011 | Western Digital Computers & Internet
I am trying to install a WD3200BEVE hard drive into a Dell Inspiron 6000 and it reads "Internal HDD Error" I received this hard drive from Dell after my previous hard drive WD600 went bad. Do I...
It's possible that the only problem is that the replacement disk-drive needs to be "initialized" for first-time usage. Or, it's possible that your Dell won't support your new _larger_ disk-drive.
Did they send you a disk-drive with _greater_ capacity than your old 60GB drive?
It's possible that they "upgraded" you, because they had no (small) 60GB disk-drives in inventory.
Take your Dell "System Restore" set of CD/DVD disks, and reinstall Windows.
The Windows Installer will "initialize" your disk-drive.
Dec 18, 2010 | Western Digital Scorpio WD600VE 60 GB Hard...
Looking for possible hard drive how hard is it to self install --with windows xp
A few simple steps:
0. find your original Dell "System Restore" set of CD/DVD disks, or order a replacement set from Dell, or run software on your computer to burn a set of "System Restore" disks.
1. do an "inventory" of installed programs (Adobe? MS Office?) and extract any "license-keys" you need (anti-virus software, purchased software).
2. backup your E-mail and contacts and music and other files, either to an external disk-drive, or burn some CD/DVD disks, or copy across your local network to another computer.
3. turn the computer off
4. disconnect the AC power
5. remove the battery
6. remove the old disk-drive
7. determine if it was an EIDE ("parallel-ATA") drive, or a SATA drive, and buy a new drive of the same type
8. mount the new disk-drive
9. reinsert the battery
10. reconnect the AC adapter
11. take your "System Restore" disks, and "boot" from the first disk, and reinstall Windows and the Dell applications
12. run Windows Update repeatedly (Service Pack 3, post SP3 fixes, Internet Explorer 8) to get all the fixes, and the fixes-to-the-fixes
13. install anti-virus software
14. install other purchased software, using license-keys you preserved
15. download the latest versions of "free" software (iTunes, Adobe Reader, WinAmp, et cetera)
16. import your "data" files
OR.................
if both the "old" and "new" disk-drives are SATA, and you have a desktop computer with two "unused" SATA ports, you can use software, such as the commercially-sold "Partition Magic", to "clone" the old disk-drive, and to "expand" the volume to span all the "unused/unallocated" space on the new drive, e.g., copy 20GB from "old" to "new", and then "expand" the 20GB partition to the full size of the "new" disk-drive. Install the new drive into your notebook computer, and enjoy the additional "free" space.
Sep 07, 2010 | Dell Latitude D600 Notebook
DELL STUDIO 1535 WILL NOT BOOT UP ERROR CODE 0146
That is a bad hard drive or sector in hard drive code. Try and run an FDISK on the drive or reformat the drive with your factory restore disk. If you are unable to format the hard drive replace it with a new one. That takes a SATA "serial ATA" hard drive. They are universal so any manufacture name replacement will work.
Aug 16, 2010 | Dell Studio 17 Laptop
I have an older dell computer and teh hard disk is
No the O.S. will not still be n the system. You will have to reload it. If you have the original disk, that is. Also take ALL of the pertinent info. you want and load to a disk. Such as, pictures, documents, all downloads you have put in the system including the setup. If you don't know how,email me and I can help. Otherwise,insert a blank C.D.,wait for auto play, select the programs, and or pic. or doc.s. right click and choose send to unless you have the option of "burn to" then use that one. I hoped this helps.
Jul 20, 2010 | Dell Dimension 2400 PC Desktop
I have a latitude c610 and on start up a message saying media test failure check cable.can any one help.
Press F2 to go into the BIOS and reset it to factory defaults and reboot the laptop. If you still get the same message, go back into the BIOS and see if the hard drive is showing up in there, if it is then that means the OS has corrupt files and you would need to wipe out the drive and restore the laptop back to factory defaults.
If the BIOS doesn't show the hard drive in the BIOS then that means the hard drive is bad and would need to be replaced.
Jan 01, 2010 | Dell Latitude C610 Notebook
Dell DV051 - message no boot device
Go into your BIOS by pressing F2 and see if the hard drive is being recognized in there. If it is then reset defaults in the BIOS and reboot and see if the computer will boot back into windows. If it doesn't then you'll need the discs to restore the computer back to factory defaults. If the hard drive is not being recognized in the BIOS then make sure the hard drive is hooked up properly. IF it is and its still not being recognized in the BIOS then the hard drive is bad.
At that point then you'll need to replace the hard drive and use your discs to restore the computer back to factory defaults.
Aug 07, 2009 | Dell Inspiron 530 Desktop Computer...
After factory recovery sytem wont boot
Hi, there is a good possibility your hard drive has some bad sectors, I recommend downloading a utility that will check the state of the hard drive. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
You will need to burn the ISO on a working computer, then boot from cd and run the long test. If there is bad sectors the hard dive test will fail, then hard drive would need to be replaced. Good luck!
May 22, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
Dell Dimension 4600 PC Desktop Logo
171 people viewed this question
Ekse
Clive
Clive
