Question about Cats
Bionaire litter box
The litter box is asking to be reset. I can't find how to do that
Tip
Training you cat to use a litter box
For the most part, learning to use a litter box is instinctive for cats; however sometimes they may need a little extra coaching along the way. The following are some tips to help you train your cat to using a litter box successfully.
Place your cat in the litter box after every nap, meal, play session or any other time your cat appears inclined to relieve itself
While litter box training try leaving a small amount of waste in the litter box so the scent can act as a reminder to your cat as to what the box is for
Find a good location - away from high traffic areas; preferably somewhere your cat can access at any time of day/night
Do not place the litter box near your cats food or water
Never punish your cat for having an accident outside the litter box. Instead I recommend firmly saying NO and then placing your cat in their litter box and praising them. This way they will begin to associate positive reinforcement with the litter box as opposed to negative associations.
If you have multiple cats, you should have multiple litter boxes. Like us, cats want their privacy too
on Aug 28, 2012 | Cats
Tip
Keeping your cats litter box smelling fresh
If your cats litter box is not cleaned every day, or the litter is not changed frequently, the odor will build up. Here are some tips that will help you keep litter box odor at a minimum:
Never put your cats litter box in your own bathroom. The best location for a litter box is in a small closet; preferably somewhere you keep your cleaning supplies.
Avoid using hooded litter boxes. No matter how clean you keep it, the hood will trap odors.
Try lining the bottom of the litter box with a thin layer of baking soda.
Opt for a clumping cat litter. They make it easier to remove waste.
Use a litter box deodorizer.
Be diligent about cleaning the litter box and area surrounding it
The following is a great brand of litter that neutralizes odors upon contact with moisture. I have noticed a difference since we started using it.
http://www.tidycats.com/Products/PremiumScoop/SmallSpaces.aspx
HOW DO I RESET A LITTERMAID LITTER BOX?
I HAVE A LITTER MAID AUTOMATIC LITTER BOX AND THE FRONT CENCER QUIT WORKING I HAD TO BY HAND WITH MACHINE ON PULL IT BACK INTO POSITION IT TOOK A WHILE BUT GOT IT TO GO BACK THEN LEFT IT THERE & NOW SCOOPING OUT LITTER BY HAND UNTIL I CAN FIND ANOTHER CENCER. I HAVE NEVER SEEN ANY TYPE OF RESET BUTTON ON IT. YOUR CENCERS BOTH FRONT & BACK MAY BE DIRTY TRY CLEANING THEM GENTLY WITH A Q TIP & RUBBING ALCOHOL.
Jul 28, 2014 | LitterMaid Elite Mega Multi-Cat Litter Box
What is the best litter box for my kitty?
Little kittens require a litter box with sides low enough for them to get in and out easily. You should visit http://www.shopzilla.com/cat-supplies/litter+boxes/31000200/products and you should find the right litter box for your kitty.
Aug 15, 2012 | Cats
What are the advantages of covered litter box?
Covered litter boxes prevent stains on walls from cats that usually stand up to ***** and scattering of litter by cats that scratch excessively inside the litter box.
Aug 15, 2012 | Cats
When should I refill the litter in my cat's litter box?
It is recommended to completely empty and clean the litter box once a week, and then refills it with new litter.
Aug 15, 2012 | Cats
Why is the height of a litter box important?
You want your cat to be able to get in and out of the box with ease, but high enough to keep the litter from going everywhere. The average height for litter boxes is 6 inches; however you will need a lower litter box for seniors and perhaps kittens as well.
Aug 14, 2012 | Cats
How much litter should I put in the litter box?
You should have enough litter to allow your cat to easily cover any waste it leaves behind. Make sure that there is enough so that they don't feel the bottom of the litter box. You should give your cat a minimum of a 2 inch base of litter in the box.
Aug 14, 2012 | Cats
Cats Logo
83 people viewed this question
Top Cats Experts
Tom Chichester
RANDY POWERS
Level 1 Expert
isojim
Level 1 Expert
Are you a Cat Expert? Answer questions, earn points and help others
