Question about Boating
I have 1999 evinrude 70 hp 4 stroke model e70pl4ee. It quit running while we were cruising around on the lake. will not turn over now. I can turn key but it will not turn it turns once then nothing.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 227 Answers
Friend it sounds to me you got a blown motor
Posted on Dec 19, 2013
2 Suggested Answers
  • 4 Answers
SOURCE: about 4 yrs old 90? hp 4 stroke outboard runs
ignition timing may be off slightly.
Posted on Mar 13, 2010
2010 150 Evinrude E-Tech. Motor was running great then just shut off. Will not start again.Could it be it needes to be reset, all 4 lights at tach light up showing good.
first bit of advice
do not use e-mix fuels in outboard engines
WHY
because ethanol separates from the fuel if not used continuously so letting it stand between outings is not good
secondly ethanol is hygroscopic which means that it absorbs moisture from the air that is going in via the tank vent and that results in corroded aluminium parts and rusted fuel tanks and outboards operate in a very moisture laden environment
now for the problem
being a late model engine , it should be a 4 stroke and like any 4 stroke engine , check the timing belt/chain, crank/cam position sensors , ignition module
it is important to check all harness connections as salt water rapidly causes corrosion in electrical connections and components
have the service agent do a scan for fault codes remember this
Suzuki out board 2 stroke motors were used in the early suzuki 4x4 cars and modern 4 stroke engines are simply car engines on end
Sep 18, 2017 | Clymer Evinrude/Johnson 5-70 Hp...
1983 9.9 evinrude runs good on land but will not accelerate under load
Possible wrong plugs, bad plugs, bad coil, bad wires, or any combination.
Apr 02, 2017 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
How do i fit a rectifier to a 2013 25hp evinrude 2 stroke???? Rectifier-4wires-2go battery & 2 go AC lighting coil system. Need to identify were to connect my 2 coloured wires from rectifier????
This is what Johnson say;
Technical Contact Information
We Take Your Boating Pleasure Seriously!
Your selling dealer has a special interest in your satisfaction and should be consulted first if you have any concerns about your Johnson power product. Your authorized Evinrude dealer is your primary contact for service, product information, and Evinrude and Johnson® Genuine Parts.
Protect your investment. Please read your owners manual for all operation and maintenance information for your engine. It lists all the adjustments and routine maintenance procedures for your motor, including off-season storage and pre-season service. We encourage you to work with your authorized Evinrude dealer for all the services you require.
If you have a concern with your engine that your dealer is unable to resolve, please have your engine model number and serial number available, and contact us.
Ta
Take a look at these videos though.
https://www.google.ca/search?q=25+hp+evinrude+2+stroke+rectifier&rls=com.microsoft:en-US:IE-ContextMenu&source=lnms&tbm=vid&sa=X&ved=0ahUKEwjVu_XQ2ZnLAhVMQCYKHbMwBnoQ_AUICCgC&biw=1600&bih=729
25 hp evinrude 2 stroke rectifier Google Search
Feb 28, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
What Year, HP, and Model is my Evinrude Outboard Motor with Serial Number 10812
Try MFG website, or their customer service email.
You may find fellow owners that have created an online "club" and they will have the information for you. It sounds like an early model. Wiki may have information about the complete series, similar to the details they usually have about cars.
Apr 11, 2015 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Year model serial number
1978 It is in the model on an Evinrude. 6804.... 6 HP.....1978
Jul 22, 2014 | Clymer Evinrude/johnson Manual 2 Stroke Ob...
Boating Logo
185 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
