Question about Northstar 6000I GPS Receiver
Northstar 6000i display is dim even though brightness level is at max setting.
4 Suggested Answers
  • 43 Answers
SOURCE: yes my northstar 6000i keeps losing gps signal
how old is you Gps antena ,with a older one it can happen that they lose fix
Where is the Gps antena fixed inside the boat or outside
Allway try to put tha antana outside. abou 20 % more signal
Look after the antenakabel if the kabel is a little bit broken water coms inside thae kabel an the signal gets lower.
Posted on Oct 15, 2009
  • 508 Answers
SOURCE: leak inside gps
Leak inside a gps is usually just a battery, sometimes they overcharge for to long and when happens the battery deforms and leaks. I have no idea where to send them to for repairs, bbut usually they are not that complicated to get into them and remove and replace the battery, they batteries in most gps units are the same size and usually the same shape as cellphone batteries, they just have different connections on the outside of them, but the insides are usually the same, also you might have one that you can run without the battery in it. I would suggest that you might want to open (if no warranty on it) up carefully, remove the battery and see if you can run it that way. Be advised though that if you do this, any power interruption to the unit while you are driving will cause it to shut down and you will have to start your trip entry all over again. Hope this helps.
Posted on Apr 26, 2010
SOURCE: I have a Northstar 6000i
Probably the data didn't go past 2010. I have a Northstar 951XD, and first time out this year, no more tide track data - my manual says it only went fron 1994 - 2010. So how to get updates?
Posted on Jun 19, 2011
When I go to text portion using kindle books, the page dims even if the brightness setting is at max
The option to keep the display bright is not found under settings in the Android app, but under the font settings. If you tap the centre of your screen whilst reading your book the icons will appear at the top of your screen. Click the font size icon, and a drop down list of settings will appear. The one at the bottom deals with brightness.
Mar 14, 2016 | Samsung Galaxy Tab 2 7.0
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Dose
Jul 14, 2015 | 2008 GMC Sierra 1500
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
How do I get some keypad buttons working on my 6000i Northstar chart plotter?
good luck with that most companys wont repair there systems they update you to a newer one for about 500 dollars more
Mar 29, 2013 | Northstar 6000i 12" Color Display With...
Brightness on cf 29 toughbook
The backlight behind the LCD display is worn out and is built into the screen, the part can be replaced but it is a very tricky repair, most technician opt to replace the screen.
May 09, 2012 | Panasonic Computers & Internet
I have a Northstar 6000i that will not display the tide track information. It has for 3 years,and now has a message stating that it can't display the information for the current date.
May 15, 2011 | Northstar 6000I GPS Receiver
How do I get a manual for a 6000I?
Retrevo has the manual to the NorthStar 6000i here: http://www.retrevo.com/support/NorthStar-6000i-GPS-manual/id/534ag415/t/2/ . You will need to enter a code to download the PDF. This is the Quick Start Guide and the Reference Manual.
I hope this helps.
Apr 30, 2011 | Northstar 6000I GPS Receiver
My 6000i flashes No Engine Data
I researched my problem on the web, found several posts on various forums that helped. Bottom line, I determined that my 6000i installation did not include a gateway. I did that by eye balling the system after removing some panels.
Jan 30, 2010 | Northstar 6000I GPS Receiver
Yes my northstar 6000i keeps losing gps signal
Aug 27, 2009 | Northstar 6000I GPS Receiver
Brightness Question
There is a way of dimming the display and it is by holding the power button for more than 3 seconds. After 3 seconds the display will lit up or dim depending on how it was before.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Northstar 6000I GPS Receiver Logo
80 people viewed this question
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
