Question about Ovens
Removal of the element from a Westinghouse wall oven model PXN698S*40
SOURCE: Oven problem
microprocessor burned out? There was a problem of this with the double ovens, after the top oven went through a cleaning cycle.
Posted on Sep 29, 2007
  • 1314 Answers
SOURCE: westinghouse wall oven
some times you can somtimes you have to replace them if the motor bearing is worn
Posted on Jan 19, 2008
SOURCE: instruction manual for Westinghouse wall oven
Obtained info from retailer
Posted on Jun 22, 2009
  • 291 Answers
SOURCE: Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Posted on Aug 31, 2009
SOURCE: westinghouse silhouette electric wall oven and
how to remove the door
Posted on Sep 06, 2009
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
I am trying to install my oven element. I am replacing old one. Oven is Westinghouse Model POL667S
tand pull the elelment out about 3". The element should lead back to a small plate at the back of the onen. Remove the two screwsi at the back of the oven.
Pull the element out about 3" and this will expose the connecting
wires, dissconnect them and remove the element. To install the new one, Just
do the removal procedure from last to first.
Nov 30, 2010 | Ovens
I need the bottom heating element in an old westinghouse wall oven. the model # is OG25HXO
I am not certain what geographic region you are in but... Bake elements are often generic between brands. The key is to match up voltage, wattage, size, bends and terminals. Here are 2 pages of westing house elements:
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Range+%2f+Stove+%2f+Oven&Brand=Westinghouse&PartType=Element+or+Burner&Electrical=Yes
I tried searching using OG25HXO with little success even on westinghouse sites US and AU.
Thanks for choosing FixYa,
Kelly
Nov 18, 2010 | Ovens
My f&p wall oven model number BI602 is not reaching temperature
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer.
Mar 09, 2010 | Fisher and Paykel Ovens
White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Dec 18, 2009 | Ovens
Westinghouse POC700M Ultimate One wall oven. We are putting a new element in it. How many wires should connect to the element on either side (ie. looking into the oven left and right)?
if you have not removed the old one yet . reinstall the ones onthe right to the right. and the same on the left . there is on most ovens only two . mm
Nov 22, 2009 | Ovens
How do i replace oven heat element? It is a GE Profile electric glass top range, model # JBP90WV2WW serial # ZM203767G
Turn off the power to the oven. Remove the oven racks. Unscrew the element retaining screws on the rear wall. Carefully pull the terminals out of the back wall of the oven. Remove the wires. Place the wires on the new element,slide it into the opening,tighten the screws,replace the racks,turn on the power.
Nov 12, 2009 | GE Ovens
I have an electrolux double oven eou 6330 the bottom oven element has broken.Can I buy and fit it myself as single female with very little spare cash?
Yes. You can do it. Part should be $40 or less.
Turn off the power to the oven. Remove the oven racks.Unscrew the element screws from the back wall of the oven. Carefully pull the element out. The wires may be short. Remove the wires from the element. Do not let the wires pull back into the oven cavity. Take the element to the appliance parts store and have them match it to the existing element. Attach the wires to the new element,insert the terminals into the opening,replace the mounting screws. Turn on the oven and bake away.
P.S. Your model number is not correct.
Nov 05, 2009 | Electrolux EOU6330 Electric Double Oven
Ovens Logo
50 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
