Question about Cobra Radio Communications
How to turn off a Cobra CXT345 - Cobra Radio Communications
Cobra xrs 979 wont turn on The light on the power cord is on (fuse is ok) but the radar detector will not turn on anymore. Any ideas? Thanks!
I have a Cobra ESD-9117 that wouldn't turn on. There was power at the plug end. I took it apart and took the power/volume button off. I used a magnifying glass and found the contact for the power must have bent from all the years of use. I bent it back and all is good again.
Oct 29, 2016 | Cobra Vehicle Parts & Accessories
My Cobra 7600 it keeps turning off when trying to update
Make sure the battery is fully charged before doing an upgrade. The cable won't supply power when doing the upgrade.
Mar 12, 2016 | Cobra GPS
COBRA 150 WILL NOT TRANSMENT
forgetting to turn it on. making sure its in CB not PA mode.turn squelch all the way to left and rf gain to the right
Mar 31, 2014 | Cobra 150 GTL DX Base CB Radio
Cobra alarm 1984
you'll need to reconnect/splice/repair the starter wire that was cut and attached to a relay, or into the immobilizer.
Jan 17, 2014 | Cobra Car Audio & Video
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
What is rf gain cotrol on a cobra cb radio
Rf gain on a cobra 29 is the same as on any other radio. When you turn the knob all the way to the right the RF increases to draw in signals that are far away nut if you turn it to the left only the nearest stations will be picked up.
Sep 22, 2012 | Cobra 29 LTD CB Radio
Where can i get tuneup specs for Cobra 18 wx st extra low modulation
The cobra 18 wx st is the worst radio Cobra ever made. I don't know why they still make it. It's not gonna do much no matter how much you tune it up. Its a bad radio.
Get a cobra 29, and turn VR4 all the way counter clockwise.
(this will not work on the 18)
VR2 is modulation in the 18 wx st. adjust it while checking on a watt meter to see when its all the way up.
Sep 20, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Lost the manual haw do u turn radios on?
Press and hold the MODE/POWER button (top button right of the display) to turn the radios ON or OFF. Need the manual? You can download/print it here:
http://cobra.com/downloads/manuals/Cobra%20Manual/COBRA_MANLS/GL_MANLS_WEBSITE/GMRS/PR190_MANL.pdf
Dec 30, 2009 | Cobra microTALKPR 190-2 Two Way Radio
Cobra xrs757 X Band
The x-band is the considered a "trash band". It picks up things like automatic doors at supermarkets and such. About every radar detector made has an X band for non-police radar. There is no way to turn this band off on the XRS-757.
Holding down the dim button for 2 seconds turns the V alert on/off
Holding down the city button for 2 seconds turns the Spectra on/off
Holding both city and dim together for 2 seconds turns K and Ku band on/off.
Dec 18, 2008 | XRS-757 Radar Detector
Radio Communications Logo
50 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
