Question about Kenworth T600 Mirror Cover: Chrome Plastic
When i turn the AC on the braker Works for a while then stops
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
It sounds like u need to recrger youer a c unit but there is n ez way to find out for sure if thats it or not start youer car let it heat up to normal timp then tron on the fan not the a c unit u will here the fan, or fans runing n pushing out some air it may not be alot but. there will be some for sure if there is a bit of air comeing out of the vants the thr prblam is in the vake umim stam .now if u r going a good amont of air fome just the fans runing that this time then it sounds like its the ac uint .now with the fans still on n in the hi pozishn tron on the ac unit to max cool .at this time if u will get out of youer car an go to the fornt of it n look dound at youer motor .n see if u can find youer ac unit ,ifd u now weill lasin you sode here the sound of the ac unit clcing .witch sound like a vary loud klik ,as the unit wokes it will keep makeing this sound leting you know that the unit is working properley if you do not here the sound fome the ac unit it mine that it may need to be crarg or that the clahe my be going out
Posted on Aug 01, 2013
Outside heat stops ac operation
clean coils seee if it makes a difference. all air-conditioners are designed by mfg. to run in a ambient temperture of 95 degrees. after that they lose effiency.
Feb 06, 2014 | Dometic Rooftop RV Air Conditioner
Kenworth trucks mechanical problems
you have a bad braker need to change it out
Aug 01, 2013 | Toys
Bobcat 225 does not produce ac current 110 or 220?
Probably you need to act the braker, put the idle at max (pull throtle) and let it run for a minute, that will reset the braker.
Dec 03, 2010 | Bobcat Miller 225 Welder Generator 907209...
An lg nep plasma split system air con. when its turned on it comes on for about 3 seconds before turning it self off?
go to your main switch board turn the ac unit circuit braker of for a minute then turn back on. it pretty much just opens its fins then beeps then closers?
Nov 09, 2010 | Heating & Cooling
Dryer made a cracking noise as wife attempted to turn on, dryer won't work as well as washer stopped at same time. have reset circuit braker no luck.
does the dryer use a 240 volt plug in there are two brakers one for heat and the other to run dryer look for two 60 amp brakers they may be at pannel or located out-side depending how old house is.
Dec 16, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
Usually trips breaker but occasionally works fine....when hooked to higher amp breaker line works fine.
it could have a small leak to ground on it,,, thats why it trips the brakers,, on a higher braker the leek off also needs to be higher than 50milly amps to trip the braker,,, this unit uses 13 amps
Oct 31, 2009 | Faberware 12-55 Cup Coffee Urn
My Duo Therm Runs good until the outside Temp. Reaches about 75 dregees Then starts kicking off the braker. What would cause this?
Too many things on the same circuit. Try turning everything electrical off but the ac and see if it stops tripping the breaker.
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Kenworth T600 Mirror Cover: Chrome Plastic Logo
83 people viewed this question
Top Unknown Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Unknown Vehicle Part and Accessory Expert? Answer questions, earn points and help others
