Question about Frigidaire FGF326AS Gas Kitchen Range
The light is very dull, not bright as it is when on. comes on and off as it feels like it!
  • Official Brand Answer
  • 4,342 Answers
Hello Mike, thank you for your question! Let's try resetting the range by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the range back on. If the issue continues, then more than likely the unit could be experiencing a faulty light switch or a potential wiring failure. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Posted on Aug 01, 2013
Zenith pvr6069 rk is out of focus for letters and picture not very bright
First this set should have a production date on the rear of around 1995--fairly old.
If letters outlined in red etc--a convergence problem--either adjustment with remote (in menu) or a circuit problem in same area.
If picture dull and darker--locate the 3 large lens inside from the rear and wipe them clean--they are the light source for the sets picture and if dirty will cause a dark dull picture.
Let me know if questions.
SD TECH
Apr 22, 2012 | Televison & Video
The lights of my 1996 toyota corolla is very dull as compared to the newer cars. I want to make it brighter how can I do it please advice. thanxs
if the bulbs are H4 you can try buying XENON gas filled 55/60 watt with a temperature heat color of 5300K they give of a very bright white light, but make sure that your lights are getting 12 volts to the lights first,if they're not it could be the reason that they are dull,a lot of european cars have XENON H.I D light systems fitted to them this is why they look so bright, but these are expensive......hope this helps....cheers
Jul 10, 2011 | Toyota Corolla Cars & Trucks
The projector is not giving a bright picture. The image on the wall is very dim
I you were using the projector in the same room with the same ambient light and if you notice this problem try increasing brightness, if still the brightness is not sufficient then it is time to replace the projector lamp.
If you have moved your projector to a different place, check if the existing light / ambient light in that room is making the image look dull / not so bright. If this is the case, try to reduce the ambient light
Mar 09, 2011 | Dell 1100MP Multimedia Projector
I have a problem with the color of the pictures that comes out of my canon dslr 400d rebel xti. when i take pictures and compare it with other canon dlsr, my picture looks dull and lifeless. it also the...
hi there,
the common difference between canon and nikon is the color they produce. you can try to change the White Balance setting on your Canon to the suitable mode e.g cloudy, tungsten, daylight, etc.
if you still feel that the picture is dull, don`t be shy to use graphic software such as Adobe Photoshop, Picasa, etc. to enchance the color/brightness/contrast of your picture
hope this will help
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Jun 06, 2010 | LeapFrog Leapster 2 Learning System
How to test oven igniter
The best way to test the igintor is with an amp meter. Connect a clamp on amp probe to one of wires going to the ignitor (either one is fine) turn the oven on, match the current you get from the amp probe to the rating on the gas valve to see if you have enough current. (typically you need 3.2 amps for most systems).
As ignitors get weak the resistance in them gets higher causing the amp draw to go down.
You can also get 'a feel' for the strength of the ignitor by how bright it glows, when working right, the orange will be bright almost whiteish in color. As it ages and weakens it will be more of a dull orange.
As a rule of thumb, if the ignitor is glowing and the burner will not come on the ignitor is bad.
I hope this helps
May 05, 2010 | Frigidaire FGB24T3A Gas Single Oven
I have acer 4315 aspire model.. i have a very dull screen.. it was fine before when i bought it. but after 3 months now it is very dull.. Though the brightness is full 100% please help me, thanks.
the brightness light might gone bad. u have to examine the system by a authorized service centre or some qulified technicain.  may be hey could repair it without replacement of screen.
Nov 18, 2008 | Computers & Internet
Please help
Well, Declan try go to your display properties by right click on your desktop then left click properties. Go to settings tab and click the troubleshoot button.
Im afraid to say this however, its possible the your monitor has a problem because most laptops and as well LCD's and Flat Screen TV's have its disadvantage of its lifespan. Since these types of screens have limited feature especially on display that it doesn't distribute the light image very well inspite of its low radiation to give our visual taste more better and more clear. That's why that most of these types of monitors won't get your eyes strained. But when it comes to durability, it much lesser advantage to compare with CRT monitors.
Jan 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dull screen lighting
There may be a bios setting to adjust the screen brightness or a utility installed in Windows - What brand and model laptop is it???
Jan 12, 2008 | Computers & Internet
Sony KV-32v25 low brightness and little color
It's more than likely the tube, my friend. The chances of it being a power regulation problem is kind of remote at this stage of the game....accordianman
Oct 20, 2007 | Sony KV-32V25 32" TV
Frigidaire FGF326AS Gas Kitchen Range Logo
95 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
