Question about Toys
Kenworth trucks mechanical problems
When i turn the AC on the braker is broken
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
You have a bad braker need to change it out
Posted on Aug 19, 2013
Rerouting a shorter belt on a paccar mx13 engine when the ac compressor locks up
Well your first issue is you purchased a KW product. Nuff said.
Peterbilt is kenworth.
Oct 24, 2016 | AC Cars & Trucks
I have a 2009 Kenworth W900. The ac/heater started only coming out the defrost. Now hardly any air comes out of any vents even though fan running. Cause? Solution?
The mechanism that controls the louvres for directing air flow is fubar. PIA because it is behind the dashboard.
Feb 21, 2016 | Cars & Trucks
My AC won't come on
Insufficient gas charge in a/c unit (broken drive belt ?check braker fuses
Jul 12, 2015 | AC Cars & Trucks
K104 kenworth. Heater/AC air only comes out of face vents. How can I make it come from floor or screen ect. Switch on dash is there and moves. Where's next to check.
check for a fuse for that control switch if it controls power
it may be a switch that moves valves to allow air to the vent actuators check for air line connections
talk with a kenworth service centre.
Jun 28, 2015 | Cars & Trucks
Kenworth wiring schematic
this may be available from a kenworth dealer service centre or from a shop that has serviced kenworths for a long time. Other than that go to a truck wreckers and make mud maps of where the hoses and lines go.
Jun 20, 2014 | 1953 AC 2 Litre
When i turn the AC on the braker Works for a while then stops
it sounds like u need to recrger youer a c unit but there is n ez way to find out for sure if thats it or not start youer car let it heat up to normal timp then tron on the fan not the a c unit u will here the fan, or fans runing n pushing out some air it may not be alot but. there will be some for sure if there is a bit of air comeing out of the vants the thr prblam is in the vake umim stam .now if u r going a good amont of air fome just the fans runing that this time then it sounds like its the ac uint .now with the fans still on n in the hi pozishn tron on the ac unit to max cool .at this time if u will get out of youer car an go to the fornt of it n look dound at youer motor .n see if u can find youer ac unit ,ifd u now weill lasin you sode here the sound of the ac unit clcing .witch sound like a vary loud klik ,as the unit wokes it will keep makeing this sound leting you know that the unit is working properley if you do not here the sound fome the ac unit it mine that it may need to be crarg or that the clahe my be going out
Aug 01, 2013 | Kenworth T600 Mirror Cover: Chrome Plastic
Loctio. Of ac blowermotor in a 2005 w900 L kenworth
We have no information on this truck. Please contact the Kenworth dealer parts dept, they will gladly give you the location.
Sep 14, 2012 | Cars & Trucks
I have a 1997 kenworth truck. The airconditioner compressor clutch will slip sometimes when I first turn it on. I have just replaced the compressor and clutch for this problem. Evacuated the system and...
You have a low voltage problem to the ac clutch,check the voltage to the clutch with it running,see if it is bellow 12.5 volts,it should be closer to 13.5 volts but the ac clutch relay may be the problem,or a trinary switch that is weak,and not conducting ,good negative ground.But check the ac clutch relay,this is most likely the problem.
Jul 17, 2010 | Heating & Cooling
My truck ac compressor doesn't run
Probably not enough charge in the system OR Low pressure cutout switch is bad.
Jun 05, 2009 | Dometic Rooftop RV Air Conditioner
Toys Logo
73 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
