Question about Mitsubishi Televison & Video
I have power to my coils but no spark - Mitsubishi Televison & Video
    Top Expert:
  • Mitsubishi Master
  • 12,223 Answers
I have power to my coils but no spark - 859ab0bc-c71f-4a90-ae8c-56ad078764d7.jpg04fed9bd-424c-45ad-9b35-8808I have power to my coils but no spark - fbcad702-a0dc-493d-819d-c88f4992fe03.jpgttp://i.fixya.net/uploads/images/fbcad702-a0dc-493d-819d-c88f4992fe03.jpg
Posted on Aug 01, 2013
Not getting a spark out of the coil?
The proper procedure is to first check that the coil is getting power to the positive side of the coil with key in on. It must show power.
If the coil has power to it, then check if the controlling device is turning the primary to the coil off and on-this is what the Ignition control module (ICM) does. Or in some cases a "power transistor" is used to control the coil primary (some imports, for instance).
The ecu signals the ICM (or the power transistor) when it wants the coil to deliver a secondary surge through the coil leading to a spark. The ecu (or pcm) must get a signal from the crank position sensor so it knows when to time the spark.
So if no spark, check if coil primary has power, then check secondary coil operation-if no secondary (no spark), possibly bad coil, bad ICM, or missing the crank position sensor signal.
Jan 22, 2018 | Cars & Trucks
No spark at plugs. Has power to coil
By power to coil do you mean spark comes out of coil tower or only the feed wire to the coil has power ? If only the feed wire has power the coil may be bad. Which engine do you have ?
Mar 31, 2016 | 1987 Honda Civic
James what can I do to check coils on ,2003 accord lx 2.4
Not James, but maybe I can help: Under the dash in the fuse/relay box is the ignition coil relay. This sends battery voltage on the black/white wire to all four coils. With key in on, all 4 coils should have power to them on this black/white wire. If no power, check fuse #2, a 15 amp fuse which sends power to the ignition coil relay, and on to the coils when the relay is energized by the ecu/pcm. Only thing else to cause spark is when the ecu/pcm sends a signal to the coil's Ignition Control Module (housed inside each coil assembly), which controls the primary circuit (the black/white wire), and causes high voltage to the spark plugs.
So check the black/white wire to the coils. If power there with key in on, check for spark at a spark plug when cranking the engine over. If power to coils but no spark, possibly a crankshaft position sensor or cam position sensor giving a bad signal to the ecu/pcm. Good luck.
Sep 01, 2015 | Cars & Trucks
Motorcycles Not getting spark from back 2 plugs
Sounds like you have power to the coil, but the coil is faulty and not producing a spark.
Remove the coils. Put power to it, you should get a spark when you remove the negative lead.
Oct 05, 2017 | Honda Shadow Spirit 750 Motorcycles
Zxr750l no spark at plugs but have power to coils. kill switch ok, coils ok. have checked side stand switch, fuses good. any help please.
You say you proved power to the coil but there is no spark at the end of the spark plug wire ... have you checked that spark plug wire? Could be very high resistance or open ...
Feb 24, 2013 | Motorcycles
No spark from coil 1-4
swap the coil and if still no spark on that coil it will be ignition(spark) box
Apr 23, 2011 | Yamaha XJ 600 Diversion S Motorcycles
Fully charged battery on my 1996 cb500,choke out however wont fire up just does a little puff like sound
NO - SPARK
Check for spark at spark plug.
1. If no spark, test the wire to the coil with test light and see if you have power to coil.
2.If no power to coil, make sure your on/off button is on and working.Use test light.
A. Power at the switch but not at the coil indicates a broke wire from switch to coil.
B. NO power at the switch indicates ingintion switch is off or faulty and not sending power to your switch , make sure key is on. Use trest light.
3. If you have power to the coil but no spark from the coil - replace the coil
SPARK
Check for spark at the plug
1.If you have spark at the plug, but not starting - check that your carbs are getting gas.
2.Petcock Could be off, Fuel Filter could be clogged, Carbs could be dirty or clogged and your not getting any gas.
3.Pull spark plug - If no gas present then your not getting gas, if wet then you getting gas and your flooded. Make sure you have good gasoline, Bad gas won't burn.
or your bike is worn out and dont have any compression.
With Good gas, and Good Spark, and Good compresssion, the bike will run.
If your not getting gas to your motor through the carbs, pull carb off and thouroughly clean it.
Dec 03, 2010 | 1997 Honda CB 500 S
No spark runns fine then loses spark wait 10 minutes starts
The spark plugs receives power to spark from coil pack.Check the power at the coil pack and also check the voltage at the coil pack with meter.If the coil pack shows proper power as well as voltage then its fault in spark plugs.Otherwise its faulty coil pack.The coil pack receives power from battery.so also check the voltage of the battery it should be exact 12 volt.
If the battery shows low voltage then the battery needs to be re-charged.
Then check out.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 1992 Pontiac Bonneville
Televison & Video Logo
14 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
