Question about Wagner Brakes 2004 - 2009 Cadillac SRX Parking Brake Shoe PAB784 Rear
How to adjust parking brake on 2004 cadillac srx
2004 srx cadilla losses all electrical power. no power at all even inserting the key..no light at the dash completely no power
What happened before this ? Did you make any changes? Did it just die or it happened after it was parked a while. How did you get into the car ..with the key or power lock operation.. Give me more information.
Aug 04, 2015 | 2004 Cadillac SRX
Replaced the starter on a 2004 Cadillac srx and now the hazard light comes on when pushing the brakes
SOUNDS LIKE VAULT OR WRONG BULB IN BRAKE LAMP SOCKET. STARTER SHOULDN'T HAVE CAUSED PROBLEM
Dec 27, 2013 | 2004 Cadillac SRX
2004 srx rear running lights went out. Lights come on when brakes are applied and when turn signal is applied
Sounds like you have a blown fuse. Check owners manual for location of fuses, should be under steering wheel.
Feb 07, 2013 | 2004 Cadillac SRX
I have 2006 Cadillac SRX and the ignition will not start and the key is stuck. Please advise what it might be. Thanks!
may be pressure in the steering wheel or the shifter is not all the way in park try turning the wheel to eliminate any pressure if any and turn the key at same time also try pushing the shifter into park and turn key at same time tilt the steering wheel up or down if none of these works let me know whit more detail on how it started and i'll be as helpful as possible thanks
Apr 03, 2011 | 2004 Cadillac SRX
2007 Cadillac SRX rear tail light stays illuminated after taking foot off brake, also comes on and off, flicker, without brakes depressed.
your brake switch needs adjustment, located down under dash on brake bracket, when the brake is depressed it lets the switch out, and when the brake is not depressed the switch is in. adjust the switch by screwing it closer to the pedal so it gets depressed more, usually 2 turns will do it
Jan 21, 2011 | 2007 Cadillac SRX
My 2005 cadillac srx is stuck on park, how do you de-activate it
hi i have a 2004 cadillac cts that is stuck in park when the ing key is turned on the ing sencor 10 amp fuse is blown
Jan 07, 2011 | 2005 Cadillac SRX
Wagner Brakes 2004 - 2009 Cadillac SRX Parking Brake Shoe PAB784 Rear Logo
Top Wagner Brakes GPS Experts
Are you a Wagner Brakes GPS Expert? Answer questions, earn points and help others
