Question about GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator
Change out paddle on water dispenser - GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator
How to replace broken water dispenser paddle?
Good Afternoon Friend,
I understand you want to know how to replace the water dispenser paddle in your Electrolux refrigerator, model# E23CS786SS1. Typically, this is not a di it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to replace the dispenser paddle with ease. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Changed out water valve. not getting water out of dispenser now
Check for voltage at the valve when the dispenser paddle is depressed, if you have 110 volt or higher you switch and door is functional. Disconnect the water line under the freezer door and hit the dispenser paddle again. If you have water there then the door is restricted inside the freezer door (most likely ice).
Good Luck
Dec 06, 2013 | Hotpoint HSS25GFP Side by Side...
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Water Dispensing Paddle
My water dispensing paddle also snapped off. Where to get replacement part and how to replace? what's the cost?
Jul 05, 2008 | Frigidaire FRS23R4A Side by Side...
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
37 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
