Question about Hamilton Beach Single Serve Scoop Coffee Maker
Hamilton beach scoop won't brew - Hamilton Beach Single Serve Scoop Coffee Maker
I need to know how to change the filter and when it needs to be done
You can by the filters at target and the replacement filter should come with instructions on how to change it
Sep 04, 2009 | Hamilton Beach TrueAir 04381 Air Purifier
Switch is bad will not turn on.
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to just solder it back on...
You might be able to pick up spare parts if you scour eBay long enough.
Apr 08, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic Breeze Quadra Silent Air Filter
The unit works without them. Mine were broken for a year and worked fine.
Dec 10, 2008 | Sharper Image Professional Plus Ionic...
Lights won`t work,buttons on front and remote will not change the motor speed,stuck on low,ECO Quest Breeze AT.Thank you.
Did anybody solve this for you? The same thing happened to mine! All purifier lights come on but it's stuck on low!
Sep 18, 2008 | Ecoquest Breeze AT Living Air Purifier
My Air Purifier will not start. Bought new HEPA and Carbon filters and nothing.
I'm not exactly sure what is the problem with your unit since in the title you say it won't start, but in the body you say it won't stop!
If it won't stop just unplug it. I'm assuming that's not your problem though.
If it won't start check the 2 safety interlocks. These automatically stop the unit when you take off either the front cover or the top cover. (This is so you don't stick your fingers in the fan while it is running and sue Hamilton Beach.)
On my unit the top one stopped working because the small plastic tab on the bottom side of the top cover broke off. This tab is designed to press into a switch inside the unit when the cover is properly installed. I over rode the switch by placing a small folded up piece of cardboard into the switch slot and taping it in place. This activates the switch full time. The only drawback is the unit will not shut off automatically when the top cover is removed. This could be a problem if you have an inquisitive toddler or child around the house. I only recommend this modification if you don't have small children around!
The front cover has a similar interlock and can be disabled in much the same way.
I hope this helps.
Oct 22, 2007 | Hamilton Beach TrueAir 04161 Air Purifier
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Hamilton Beach Single Serve Scoop Coffee Maker Logo
Top Hamilton Beach Air Purifiers Experts
Are you a Hamilton Beach Air Purifier Expert? Answer questions, earn points and help others
