Question about Garden
Pacific hydrostar 2800 pressure washer
My pump is blowing oil out of the fill spout. This thing doesn't have but about 3 hours on it. Do I need a new pump? Thanks!
    Sergeant:
  • 402 Answers
Did it overheat if so replace the pump it will overheat again only two things the packing can be worn overpressuriztion in pump head by a faulty unloader is another this symptom has many variables even a cracked plunger can cause this i can and will help you give me more info like is the oil milky in color or is sight glass melted etccc.will be glad to help 30 years plus exp..
Posted on Aug 05, 2013
Testimonial: "I'm going to guess it overheated. The machine doesn't have more than three hours on it and its only been run for 30~45 minutes at a time. No water leaks and no water in pump oil. However when I changed the pump oil it was black. How do you prevent one from overheating? If I'd been running this thing for hours I could understand, but 30 minutes and it blows the pump? Thanks a million for your help!"
  • Mike Aug 06, 2013
4 Suggested Answers
SOURCE: Help! i have a pacific hydrostar 65078. Engine
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Posted on Nov 23, 2009
kel1guy2002
  • 3740 Answers
SOURCE: How full and with what oil to fill pump vent.
Any pressure washer pump should be no more than half full. The reason is if you fill it completely up when the piston strokes it will blow the seals out of the pump. Usually there is a sight gage on the side of the pump. I will look your model up and see what I can find as far as quantity for the pump. I won't be too long just read the 2nd response and please do not rate this one. I will get back to you ASAP.
Kelly
Posted on May 17, 2010
SOURCE: Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Posted on Oct 13, 2010
Testimonial: "Thanks, great web site!"
Throttle linkage diagram for pacific hydrostar pressure washer 4 hp
For a throttle linkage diagram, contact Pacific Hydrostar directly.
Apr 21, 2017 | Garden
How much oil does a pacific hydrostar in the pump their is no site glass pump 95618
There is no oil in this pump. When storing it long term , put some automotive antifreeze in it. Disconnect the water hose and tip the unit on its face to drain water out of the inlet fitting for short term non freezing times.
Aug 22, 2016 | Garden
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Apr 03, 2015 | Computers & Internet
I just purchased a 98444 Pacific Hydrostar Power Washer. I was checking out the oil level in the pump and it appears to be bone dry. The manual calls for 75w/90 non- detergent oil but does not tell me the...
The oil cap should have a dip stick if not it should take maube a quart but add a little at a time untill u see some oil. But do not fill it all the way to the top
Sep 21, 2013 | Garden
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
Jul 09, 2011 | Plumbing
Pump oil change, how much oil
There should be a drain plug (bolt) at the bottom of the pump to drain the oil. Undo bolt and drain the oil. Replace bolt and fill pump with new oil. Look for a sightglass on the side of the pump. Fill so the oil level is in the centre of sightglass.
Jan 29, 2011 | Northstar Pressure Washer 2800 PSI
Oct 13, 2010 | Garden
What oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Dec 17, 2009 | Karcher 2500 PSI Pressure Washer
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
Nov 20, 2009 | Garden
Garden Logo
367 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
