Question about Mackie SWA1801 Subwoofer
Speaker membrane Hello i'm from Saint-pierre et Miquelon I've 8 SWA 1801 and i have a problem with 4 of them the membrane not working and i'm lookink for parts .can you help me to find thanks a lot
  • Yannick Kello Aug 02, 2013
    I Need parts for subwoofer SWA1801 . Where can buy . Thanks
4 Suggested Answers
soberanis54
SOURCE: swa 1801 mackie blown capacitor
mackie 1801 f 1 blow and tip 122 bad
Posted on Mar 05, 2012
palaboy
  • 5807 Answers
SOURCE: Model swa 1801 Fuse 240V 4A
check for integrity of the main amp and the torroidal transformer.
here is a guide , how to check for transistor
if there is a continuity on the primary terminal of the transformer.
Have a tech to guide you , should you need to DIY.
Posted on Oct 26, 2012
palaboy
  • 5807 Answers
SOURCE: Can you tell me what
As per spec sheet states:
Input Impedance = 50K for the Active System
SWA1801 Active Subwoofer Spec Sheet - Mackie
For the passive speaker =4 ohms
Trying to bypass module for wwireless speakers.. Is there a code??
No. If the system came with the wireless rear amp, then it will not work without it.
Jan 18, 2013 | Samsung Wireless Receiver Module Swa-4100...
Model swa 1801 Fuse 240V 4A burned out ! I replaced it but still get no power (any led stay off) What can it be ?
Sep 17, 2011 | Mackie SWA1801 Subwoofer
Can you tell me what the impedance is of the SWA 1801 speaker?
Sep 14, 2011 | Mackie SWA1801 Subwoofer
Mackie swa 1801 power amp R7 100 ohm resistor smokes when powered up..
You likely have other parts blown as well, but Q3 (MJE15033) AND/OR r8 (1 OHM/0.5 Watt) are blown. I suspect that Q3 has a base-collector short and you will find several of the output transistors are fried as well Q4, Q5, Q15, Q16. I suspect that the Zeners D14, D25 may be blown.
When restarting this, put a 100 Watt lampin series with teh 120 volt power to limit current and avoid destroying freshly repaired parts due to a few bad ones not found.
Aug 17, 2009 | Mackie SWA1801 Subwoofer
Just connected the SWA-4000 wireless amplified to my samsung ht-z310 - the readout on the display is "Rear Chk" there is no sound from the rear speakers- any help is appreciated
swa-4000 wireless module isn't compatible with htz310. You need to buy Samsung's swa-3000 to work with your htz310. I had the same problem. It tells you in your owners manual under conectivity where it explains about hooking up a wireless module(pg.55-60). I hope this helps.
Dec 13, 2008 | Samsung SWA-4000
Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Nov 08, 2008 | Samsung SWA-4000
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Oct 06, 2008 | Samsung SWA-4000
Swa 1801 mackie blown capacitor
Took alot of finding but you can get them from Digi-key
Sep 16, 2008 | Mackie SWA1801 Subwoofer
Mackie SWA1801 Subwoofer Logo
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
