Question about Garden
Pump blowing oil out of fill spout model 67546
    Sergeant:
  • 406 Answers
Is the oil milky in color need more info on pump,does it have a sight glass is water dripping from underneath head???let me know
Posted on Aug 05, 2013
Filling gear box with oil 2000 kia carnival
Use a bottle with a long narrow spout. Fill until oil just starts to come back out of the fill hole. let oil stop dripping from filler hole before you put back the filler plug or it will be over filled.
Aug 08, 2015 | Kia Cars & Trucks
Pacific hydrostar 2800 pressure washer
did it overheat if so replace the pump it will overheat again only two things the packing can be worn overpressuriztion in pump head by a faulty unloader is another this symptom has many variables even a cracked plunger can cause this i can and will help you give me more info like is the oil milky in color or is sight glass melted etccc.will be glad to help 30 years plus exp..
Jul 31, 2013 | Garden
My 2002 santa fe dosen't take fuel correctly,gas pump keeps kicking off,making it take for ever to fill
sound like problem with the EVAP SYSTEM.HAVE CHECK OUT. trick to pumping gas dont stick fuel spout all the way in hold it back a little then pump gas the gas vapors stored in fuel tank stopping you from pumping gas.hold spout back pump gas.
Dec 29, 2012 | 2002 Hyundai Santa Fe
How full and with what oil to fill pump vent.
Any pressure washer pump should be no more than half full. The reason is if you fill it completely up when the piston strokes it will blow the seals out of the pump. Usually there is a sight gage on the side of the pump. I will look your model up and see what I can find as far as quantity for the pump. I won't be too long just read the 2nd response and please do not rate this one. I will get back to you ASAP.
Kelly
May 17, 2010 | Garden
Where is the fill plug on the diffirential on a 1999 jeep grand cherokee laredo"
How to Fill a Rear Differential
You may need to add fluid to your differential due to leaks or changing seals, or it may be time to change out the gear oil completely. Either way, it's just a few steps to fill the rear differential and get your vehicle back out on the road!This article will explain how to fill a rear differential. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate
Instructions and Things You'll Need:
  • 3/8 inch drive ratchet with extension
  • 2 quarts gear oil (gear lube, differential fluid)
  • Side cutters
  • Oil drain pan
  • Shop rags
  • Flashlight or shop light (optional)
  • Lock tight (optional)
Filling a Rear Differential
  1. Be sure the car is raised on four jack stands and is level. It will be more difficult to fill the differential if you've only got it raised in the rear.
  2. Place an oil drain pan underneath the plug to catch any leaks or drips. Keep shop rags handy for any spills.
  3. Check your service manual for the amount of fluid your differential needs, if you're completely refilling the system. Two quarts should be enough in most cases.
  4. Remove the spouts on the gear oil containers. Peel off seals, then replace spouts. Use side cutters (or any cutting tool you've got handy) to clip off the top of each spout.
  5. Remove the differential fill plug using a 3/8 inch drive ratchet with extension. (Some models may require a hex key or screwdriver, but the 3/8 inch is the most common plug design.)
  6. Take the gear oil container and fit the spout into the fill hole. Pour the fluid inside. You can gently squeeze the bottle to speed the process. Repeat with a second bottle if necessary.
  7. Fill the differential until the fluid starts draining back out of the hole.
  8. Clean and replace fill plug. Use lock tight (thread locker) to help seal if desired. You can see my eHow article "How to Replace Rear Differential Fill Plug" (video) for more information.
  9. Take the car for a drive around the block to get the gear oil moving. When you return, check underneath for any leaks from the fill plug or differential cover.
Hope help with this.
Mar 12, 2010 | Jeep Grand Cherokee Cars & Trucks
What oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Dec 17, 2009 | Karcher 2500 PSI Pressure Washer
Toro sprewing oil
The filler spout tube may have pulled out of its seat push and twist to reinsert it down. if the oil is over filled you must drain some out to return it to its correct oil level, if it did pull out of its seat the small bolt holding the filler tube in place may have loosened up and fallen off it must be replaced if this happened.
Oct 03, 2009 | Toro Lawn Mower With Toro Power Tools
Gas leaking on top of tank
its most likely either broke the seal on the halfway of the tank or the fill spout has become damaged and needs replacement. id start by testing the pressure of the tank then deciphering whether or not its the tank or the fill spout.
Aug 13, 2008 | 1999 Volvo S80
Is there another tool besides a hand pump that we can use to put transmission fluid in the fill plug?
use an old school oilcan...the type you fill with oil of your choice, and has a finger pump action (like a squirt bottle). you should be able to pick one up with a flexible spout at any reputable auto parts suppliers.
Jul 22, 2008 | 1999 Isuzu Rodeo
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
