Question about Saeco Vienna Espresso Machine
I have a Saeco Vienna Plus and the brew unit is stuck in the machine, with the little red light blinking furiously. Help!
2 Suggested Answers
  • 40 Answers
SOURCE: Saeco Vienna Digital Expresso Maker - brew group will not line up to fit back into espresso machine
Could be a number of reasons. If you "hear" the brew group moving in one direction, stop and then move again, then the microswitches are o.k. If the sound of the movement is low and/or slow ( slower that normal), the CPU/power board may be bad and needs to be replace. If the movement is as before (same sound and movement) but not lining up, perhaps the brew drive motor is bad.
To remedy this situation, an authorized SAECO Service Center would have to open your machine and replace damaged components. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Red light from the coffe keep blinking
make sure all the doors are closed, brew group, tray, water, and disposal are all seated closed.
have you cleaned the brew group? something stuck in the grinder? got beans and water?
Sep 19, 2010 | Saeco Vienna Espresso Machine
My saeco vienna water is leaking out from somewhere underneath
If it is coffee colored water, then remove the brew unit and look under the white plastic valve in the machine, you will notice a small chamber, clean chamber of coffee grounds and make sure the little discharge to the draintray is also clear. Insert brew unit and check machine.
Jan 27, 2010 | Saeco Vienna De Luxe Espresso Machine
Brew light blinking
It is telling you that the temp on the machine is too low. It is possible that one of the thermostats on the boiler is damaged.
Sep 13, 2009 | Saeco Vienna Espresso Machine
Vienna superautomactica found a spring
That spring can fit in many places:-(
I put a blowprint of the brewingunit here.
Jan 31, 2009 | Saeco Vienna SuperAutomatica Coffee...
Brew cup stuck unable to get out
If you open the door and take a flashlight, light in the front/middle of the brewing unit. You will see a little screw, take a screwdriver and loosen it, bend little on the little plastic above where the screw was and pull out the brewing unit.
When you have the brewing unit out then you need to reset the machine and brewing unit.
To reset the machine you have to turn off your machine, open the door.
Look in the down left corner, you will see a hole, look in the middle of the machin you see another hole and in the upper right corner.
put a screwdriver or similarly in the left corner and in the middle of the machine, turn on the machine and put another screwdriver in the upper right corner. hold it in place to the machine not get any noise more.
To reset the brewing unit, first put the plastic back again (that one you loosen with the screw first).
If you look back on the backsida of the brewing unit, in the middle you will see a plastic that looks lika a handle, force it down and you will see all the other parts will move around little. Turn it to you can see the little mark on the front goes to the N mark.
Best regards
/Mirran
Jan 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Saeco vienna express deluve
That red light is there to tell you many things unfortunatly. It could have timed out on the grinding in which case if you push the brew button it will grind again. If not one of the components might not be in tight. Or it could have run out of water in which case you would need to open the water knob to let water run out the wand. If none of these help you will need to Google" Saeco Repair" and send it to an authorize repair center to have a switch replace.
Aug 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
