Question about IBM Correcting Selectric II
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
  • IBM Master
  • 3,594 Answers
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
DickyO
Posted on Aug 01, 2013
4 Suggested Answers
  • 4 Answers
SOURCE: Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
Posted on Apr 19, 2009
  • 46 Answers
SOURCE: how to install a ribbon in an IBM selectric II
Pull the orange lever located on the carrier to the side. Make sure the ribbon passes through the ribbon lift guide next to the platen. The ribbon should go behind the the thick part of the guide and through the fingers to the inside on the outside of the guide. There is a wire (usually with a white platice roller on it) sticking up from the carrier. Maker sure the ribbon goes aroung the outside of the wire. Snap the ribbon down on the carrier then close the orange lever back in place.
Posted on Jun 26, 2009
komguy
  • 2306 Answers
SOURCE: My IBM Selectric II types the wrong letters.
Sounds like the cable might have slipped off the pulley, with the cover off, check all cables to the carriage assy. You need a tool like a spring hook to gently slide the cable back on to the pulley.
Posted on Jul 24, 2009
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
My IBM Selectric II either does not type some letters or only partially types them. Sometimes the machine will type a letter and sometimes not. It happens no matter which ball is on the machine. What
First put in a mulyi part form, type on it if the carbon is ok you have have a ribbon problem. The ribbon may be very old or not properly installed or twisted.
DickyO
Sep 30, 2014 | IBM Correcting Selectric II
IBM Selectric II letter printed does not correspond to the letter typed
You could have a broken element (type ball). You could also have a broken or out of adjustment rotate or tilt tape. Those are the two wire bands that control the rotation and tilt of the element.
Dec 11, 2013 | IBM Office Equipment & Supplies
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
My IBM Selectric II will occasionally not print letters or parts of letters. Why does it do this?
Your Selectric II (a wonderful machine) is in need of cleaning and adjustment. When I did this, I got $65.00 for the service ... that was years ago. I don't know anyone who does this work any longer though a search on Google may get you results for a shop in your area. There may be a FixYa.com advertiser who can help you. Look at the ads around this answer (that is what pays the bills, after all).
Thanks for your question @ FixYa.com
Mar 25, 2011 | IBM Office Equipment & Supplies
I have a couple of IBM Selectric II Typewriters and over the last few months both just quit as if they are getting no power. One started working again but then quit again..any ideas on how to fix. Also had...
Most selectrics at this time are suffering from many gummy parts.
All of these problems are probably repairable with a good chemical cleaning and lube.
DickyO
Dec 11, 2009 | IBM Office Equipment & Supplies
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
Aug 31, 2009 | Office Equipment & Supplies
IBM Selectric - keys will not come back up
This is not an easy repair, the keylevers and trip pawls get gummy over the years it needs a chemical cleaning an lubrication.
DickyO
Feb 12, 2009 | IBM Wheelwriter 30 Typewriter
Gapping/overlapping of letters
Its sounds like tou may need a rotate adjustment. Take it in for service.
DickyO
Sep 10, 2008 | Office Equipment & Supplies
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II Logo
82 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
