Question about Goodman Heating & Cooling
Goodman CK42-1C - compressor is humming but will not run - fan is not turning
    Problem Solver:
  • 13 Answers
Most likely cause is the dual capacitor for compressor and fan is bad.
Posted on Oct 27, 2013
james3751
  • 614 Answers
SOURCE: Goodman CK36-18: Outside fan kicks on, but
Sounds like a bad capacitor. They can be bad and the fan will still run. Turn off power and check for burnt wires on the top of the contactor going to the capacitor or on the top of the capacitor.. Check terminals on the compressor also. When capacitors go bad they are slightly swollen. They can also look good and be bad . Could be compressor but start with capacitir and wires. IWork on a lot goodman units. Most of the time it is the cap.
Posted on Jun 03, 2009
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 93 Answers
SOURCE: Compressor hums but fan not turning. Pushed fan to
cap most likley
Posted on Jul 16, 2009
  • 87 Answers
SOURCE: Fan on the outside unit is not running
Fan motor is dry or going bad try to lubricate it and see if that frees it up. If not you will need to get a new fan motor.
Posted on Oct 09, 2009
SOURCE: I have my dometic Rooftop AC unit. The
Let it cool off.Install a hard start kit on the run capicator.Its only 2 wires & easy to put on.It should kick over.
Posted on Mar 16, 2010
I have a CK49-1 Goodman A/C unit, It's not cooling down I can here it running/humming but the fan is not spinning
Turn off unit now!!! You are about to burn up compressor (very expensive to replace). Either the fan motor has burnt out or the relay for the fan has burnt out.
May 07, 2016 | Goodman Heating & Cooling
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
Sep 08, 2014 | Heating & Cooling
GOODMAN U0502069173
It could be the fan motor or the compressor. Get professional help.
Aug 02, 2014 | Goodman Heating & Cooling
The fan on my outsie unit of my grand air heat pump won't turn on. The compressor hums. If I manually turn the fan it will run but very slowly.
Your description is possibly a bit vauge for the problem it could be, but starting from the compressor, question is "can you hear the compressor running"? If you can then switch off quickly and check the cooling fan capacitor. almost certainly it has popped.If it has, and even with a new capacitor it wont start, then a complete condensing fan unit is required.If the compressor isnt running, then one of a few things could be the problem. A- The voltage getting to the compressor or the cap, is not correct which points to a problem with the board. B- If the compressor is jambed,(siezed),then it is bringing the voltage down to the point where even the fan cant run. Need to check those points to determine the next course of action.
Aug 28, 2010 | Goodman CLQ36AR49 Air Conditioner
UNIT IS NOT FUNCTIONING.
See if you can hear the compressor start, if that does not start and your fan hums, it is most likely your dual capacitor. If compressor starts and fan hums, it is most likely your fan.
Jul 01, 2010 | Goodman CKL30AR30 Air Conditioner
Oct 09, 2009 | Goodman CKL36AR36 Air Conditioner
Compressor tries to turn on but takes a while
weak comperessor you need to test it first...or you may have something that jaming the fan
Sep 11, 2009 | Goodman CLQ36AR49 Air Conditioner
Ac unit fan does not turn unless i force it to turn. also not producing cold air
If the fan just hums and if you spin the fan and it runs, check out the capacitor, it is bad. Most condensing units have a split capacitor, for the hermedic unit and the fan. If the compressor runs the dual capacitor is bad on the fan side. Your choice buy the dual capacitor, or just buy a single capacitor for the fan part of it. Make sure the voltage rating and microfarad ratings are the same. They will be marked on the old capacitor, as will fan (for fan), and herm for compressor). THATS 220 VOLTAGE YOUR WORKING WITH, BE SURE THE POWER IS OFF!!
Jun 22, 2009 | Goodman Heating & Cooling
A/c compressor hums
The compressor may be fine after setting off or a day. After retyring it then if it still dosnt start either replace the run capacitor to the compressor and fan motor or have it checked to see if it is in range.
The hum your hearing could that be the contactor relay humming?
May 15, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
115 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
