Question about Uniden TRU8885 Cordless Phone
Handset is lit up but unresponsive
My handset #1 is unresponsive. It has done this before, but usually corrects itself after an hour or so. But this time it is not and has is lit up but is completely unresponsive. It did say "not registered" so we let it charge overnight and then the next morning it registered as handset #3 instead of 1. I unplugged both the base and the battery pack inside thinking that would reset everything, but it is still unreponsive. The battery shows only one car of power.....maybe I need a new battery pack?
  • Avalon23 Aug 31, 2007
    one BAR of power (not car), LOL!
  • 34 Answers
Posible or you need to intial reset the whole system completly make sur all your hand set indicate on the base make sure the power is reading ok
Posted on Oct 01, 2007
My phone displays out of range how to correct
This sounds like a registration problem. Try
de-registering the handset(s) and re-registering
to your base.
NOTE: the CS6429 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Oct 02, 2014 | Vtech Accessory Handset with Caller ID for...
Panasonic KX-TG2740
u have to try change battry its might be week so try it
Sep 08, 2008 | Panasonic KX-TG2740 Cordless Phone
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.pdf .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
Jan 03, 2012 | Computers & Internet
My samsung galaxy s will not turn on. It shows the startup screen, but then the screen just goes black again. The back and tab keys are lit up, but the screen stays black and unresponsive. Ive tried...
When the handset is on, and you can tell this by making sure the key tabs are illuminated, take the battery out, wait 1 minute, and then reinstall the battery and power the handset up. If this does not resolve your issue, then you will want to contact your wireless provider to see if the device is still under the manufacturer's warranty, they cover the first year of ownership. If it is not, I would recommend that you seek out a cellular handset repair shop, they do exist, and it is less expensive to repair, than to replace.
Mar 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
Need to fix date and time onToshiba DKT2020-SD
Depending on the type of system you have powering the 2010,this should take care of it.
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered,
press Redial,
press Speaker.
This must be done at extension 200 – usually the receptionist phone.
For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker
May 07, 2010 | Toshiba DKT2010SD Phone
How do i unlock my Nokia 6500 slide phone for free
anyway try this two sites they offer you free services
http://unlockitfree.com
http://unlock.nokiafree.org/
here is the unlock page for your mobile;
select country
select service provider
put your IMEI no
that's it
Free Nokia Cell Phone Unlock Codes
1) Unlock Nokia 6600 (Orange, UK)
#pw+399466210777312+1#
#pw+719950237732007+5#
2) Unlock Nokia 3390 (Fido, Canada)
#pw+6595657252+1# or
#pw+4474052474+1#
3) Unlock Nokia 6102 (Cingular, USA)
#pw+939652056653040+1#
4) Unlock Nokia 6820b (AT&T, USA)
#pw+895421713251412+1#
5) Unlock Nokia 6102b (Cingular, USA)
#pw+324556243142742+1#
6) Unlock Nokia 6010 (T-Mobile, USA)
#pw+748900573631603+1#
7) Unlock Nokia 3120 (Vodafone, Spain)
#pw+008923325642375+7#
8) Unlock Nokia 6101 (T-Mobile, USA)
#pw+110464135761655+1#
9) Unlock Nokia 6230 (Vodafone, UK)
#pw+737190152533105+7#
10) Unlock Nokia 7600 (3 Network, UK)
#pw+448917267516205+1#
note: {To get the p push your * key 3 times, the w is the * pushed 4 times and for + is the *pushed2 times. }
let me know if it's helpful to you
Dec 17, 2009 | Nokia 6500 Slide Cellular Phone
Can't get handset to register
After each registration of a handset, you need to hold the page button on the base for 5+ seconds. If you then get an error tone, you'll likely have to return the phone due to a hardware problem. What did you do?
Apr 05, 2009 | Uniden Cordless Phone
Need to Change Time on My Phone
1. Press [DN] + #652 with the handset onhook.
2. Enter the time (HHMMSS) in the 24-hour clock format.
3. Press redial
4. Press speaker.
This can only be done from the programming phone (usually reception).
Dec 05, 2008 | Toshiba DKT2020SD Phone
Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Jun 21, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden TRU8885 Cordless Phone Logo
131 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
