SCHEMATIC/WIRING DIAGRAM CLOCK/TIMER KENMORE RANGE 911.9342191
fridgetech
  • 473 Answers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Posted on Oct 05, 2007
the dr
  • 447 Answers
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
  • 11 Answers
SOURCE: need part number for a kenmore range clock/timer replacement
part #496225
Posted on Dec 05, 2007
gotgeek2
  • 565 Answers
SOURCE: clock doesn't work
The wiring diagram for that timer is somewhat misleading. The 120 volt clock timer motor is connected internally to the "A" (neutral) terminal and the #3 terminal. The "A" (neutral) terminal is to the immediate left of the #1 terminal.
Here's how to do the wiring for your use, (assuming a 120 volt supply circuit and a 120 volt lighting or other load):
Connect the incoming power (line) black wire to terminal # 3. Connect the incoming (neutral) white wire to terminal "A".
Connect the outgoing (load) black wire to terminal # 4.
Connect the outgoing (neutral) white wire to terminal "A".
Posted on Mar 08, 2009
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
Im in need of a wiring diagram for a Kenmore Side by Side refrigerator Model # 10657075791
The schematic should be under the kick plate grill. Remove grill and should either be in the grille or behind. Defrost thermostat is located on top of the evaporator behind back panel inside freezer
Dec 14, 2014 | Kenmore Side by Side Refrigerator
WIRING DIAGRAM FOR CLOCK ON KENMORE 91194492990 ELECTRIC RANGE
You may not get the clock component level schematic but the 'Sears Parts' can provide the unit diagram. I've had great success with replacement parts and tech info.
Aug 04, 2013 | Kitchen Ranges
Can you send a scematic showing how to wire an intermatic pool pump timer to a polaris intermatic timer so that when the pool pump shuts off so will the polaris pump yet the polaris timer clock continues...
No. I don't have a wiring schematic without knowing what voltage you are using, specifically what Intermatic timer you have, specifically what wires you have coming from breaker box, what wires are on the pump, and what pump rating plate says, what the wiring diagram shows on side of pump, whether you are wiring a 2-speed pump to a single-speed timer, specifically what is the polaris timer clock, and why this pump needs two timers if that's what you mean.
Add a comment with specific information so electrician is not guessing.
http://www.poolcenter.com/polaris-booster-install-OM.pdf
Open following link for 240Volt T104 timer wiring diagram.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Aug 25, 2011 | Intermatic T104 24h 208-277v Mechanical...
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
This range was set for self clean. When i returned home the digital display was not on, the oven was locked, I turned on the top burners to see if they were working, they are. I tried disconnecting power...
their is a thermal fuse between the power and the main clock/timer ......find the wiring diagram ...it will be located in a small brown enevelope ....either on back../or where the range drawer.is ..remove it to look ..under either on right or left...this diagram will tell you the wire color /location on the clock/timer control..let me know an good luck.../joe/
Aug 31, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Forgot how the wires go on the back of this timer
Kenmore usually glues a copy of the wiring diagram/schematic on the inside of the back service access panel, or folded up inside the control head.
If you can't find it, give me the full model number and let me see what I can find.
Jan 22, 2009 | Kenmore 63942 Dryer
Clock,timer and oven does not work on Kenmore gas Range
Oct 04, 2007 | Kitchen Ranges
37 people viewed this question
 Grubhead
Grubhead
