Question about Exercise & Fitness
When i turn on my reebok treadmill T3.2 the digital display shows confused all are flashing and i can't program it and sometimes it runs and then suddenly it speed down to zero and stop....how can i solve this problem?
    Top Expert:
  • 12,223 Answers
Run the software calibration, go to under the HOOD cover Motor,follow the instruction or read the owner manual and follow the steps. or download the manual from. www.fitness.manualsonline.com
God bless you
Posted on Aug 01, 2013
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: treadmill stop then display an error speed
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
Posted on May 21, 2010
maxtreadmill
  • 832 Answers
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 24, 2010
  • 218 Answers
SOURCE: hi i got a reebok i run treadmill power light on
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 11, 2010
Treadmill Reebok ZR9 When machine is switched on display flashes and makes a beeping noise
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 06, 2017 | Reebok Exercise & Fitness
Reebok 8700es treadmill will show display but belt will not move
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 23, 2016 | Reebok Exercise & Fitness
My Reebok i run treadmill is not working.
If you wish to get some details about treadmill repair check the bellow added link.
www.electro-medical.blogspot.com
Jun 28, 2016 | Reebok Exercise & Fitness
Reebok ZR8 display is completely blank. Belt working fine, speed and incline keys still responsive - just can't see speed, distance etc
Hi Adrian, All a treadmill is... is a motor, running belt and console display pad. You'll find the console display pad has malfunctioned.... This can happen when something heavy is placed on it OR something hits it and if yours is under warranty then get it fix as soon as possible mate, I had a problem with my console display pad and it cost me $100 just for the pad....... My treadmill is a different brand but I can tell you the motor and running belt will last and last and last.....I hope this helps.........CHEERS..
Apr 27, 2016 | Reebok Exercise & Fitness
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Reebok I-run got E5 code on display
A simiar manual (the functions are the same ones, it only changes the carcass)
I-run manual
Just press "search" to find out a motor is failing.
Feb 11, 2015 | Reebok treadmill i-run s
Fix led displays
Check to see if the RPM/speed sensor is functioning. On some models this sensor is positioned next to the pulley on the front roller and opens and closes each time the magnet on the front roller passes the sensor.
The sensor could have failed, or it may simply be too far away from the magnet on the front roller. 1/8 " is the normal distance between the sensor and magnet. It is also possible that the magnet is missing from the front roller.
Be sure to post the units exact model# which normally starts with RBTL....
Nov 29, 2013 | Reebok Exercise & Fitness
When turning reebok tr3 on the digital display goes off and green light stays on english led and treadmill doesnt work
1) Try to exchange batteries new ones.2) see the diagram adn adjust by 1/8" or 3mms according. 3) tight the key panel flexible cable vs display board 4) then connector display board vs lower board.5) test the main motor controller bOARDEC for 5+vdc, to display board.See the block diagram how the main motor controller has 90% aprox for control functions of any treadmills.sincerely. Merry Christmas.ernesto cuadra , managua, nicaragua. 12_20_2011_7_10_29_pm.gif12_20_2011_7_10_45_pm.gif
Dec 20, 2011 | Exercise & Fitness
Exercise & Fitness Logo
50 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
