Question about Garden
Bolen160 starts runs thru warm up dies when you try to up throttle
    Problem Solver:
  • 8 Answers
Check your Choke setting after warm-up. Also, try cleaning or looking for obstructions in/around the air filter/intake. Your trimmer requires more oxygen when raising engine speed to complete the combustion in the engine.
Posted on Aug 01, 2013
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Cuts out when trying to wack
Hi Brad
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 27, 2013
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
Motor starts fine runs for five minutes then dies starts back up back up fine but no throttle response after thatfine.
if there is electronic throttle then probably needs replacement, get second hand one , or otherwise can try to take it out and clean it, if there is an access to electronic part of it try it open carefully and clean contacts with some alcohol, sometimes it helps
Apr 16, 2014 | Cars & Trucks
Johnson outboard stalls when it warms up
Little Johnson outboards are famous for being very easy to start, So- first pump up the gas, then set the throttle open to the neutral stop -pull thru once -then set the choke to fully closed (look down the carb and see if it is) and pull thru 2 more times- open the choke. try again --If it is not running by now you have a bad ignition, or the engine has no compression. - very likely if you are running the wrong spark plugs. You may have some shattered reed valves.
See if the spark plugs are getting wet with fuel.
Sep 08, 2012 | Boating
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
86 Ranger 4X4 2.9 fuel inj runs rough when warmed up
1988 ranger 2.9 runs great cold then after a few minutes when warmed up hesitates with intermittent black smoke from the tail pipe until i hit the the throttle then clears and will repeat this behavior...
Jan 26, 2010 | 1986 Ford Ranger 2WD
My o2 status will start warm up then will not idle, it dies. if you give it gas it runs is there a idling sensor? this happened after the weather got cold if thats any clue
have you had water undere the hood? splashing thru rain? it sounds like a bad throttle position sensor, possably some water in it. now that it is cold, it freezes up and makes reading the throttle difficult
Dec 12, 2009 | 2002 Dodge Stratus
Car wont start or starts and runs for apr 10 secs then dies
Hmmm.....Thing's to check..
1) check for loose connection's @ the dizzy, the coil, and alternater
2) fuel injecter's
3)Check for vacuum leak's around the inlet manifold/ throttle body
4) check air control valve.
Join up on www.imoc.co.uk, we have a very knowledgable mk1 section who will be able to go thru all possible causes and get you back on the road. ;-)
Oct 14, 2008 | 1985 Toyota MR2
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
