Question about Catback Exhaust 96-00 Chevy Cavalier Z24 2.2L 2.4L 2DR 4DR
Were is the map sencer located - Catback Exhaust 96-00 Chevy Cavalier Z24 2.2L 2.4L 2DR 4DR
    Sergeant:
  • 402 Answers
Your best bet is to purchase a chilton manual at the auto parts store for 15.00 and you'll have it all.or look up the actual part online ac delco only and you'll see that its a three prong connector with a small barb sticking out of it normally located in the intake system sometimes barb is not visible cause they can be inserted into other manifolds but basically a hose.if you look on top of your grill or underneath hood you should have a hose routing diagram and map sensor should be on that chart it sctually directs you to it.
Posted on Aug 05, 2013
Engine won't idle /sometimes backfires
Check the MAF-MAP SENCER or it's a throttle position sencer is bad check both by replacing them and see if it works or the last result is idle control valve
Mar 24, 2014 | Polaris 2006 Sportsman 450
Plugs, destributer, destibuter cap,wires, map sensor replaced. still not running right
check the raideator temp sencer and massflow sencer get a diagnosticreading done and work from that
Jan 24, 2013 | 1994 Cadillac DeVille
2000 silverado 1500 4.8 bank 1 and bank 2 to lean how can i fix
I have a 2001 Silverado 1500 with the 4.8 that had the same error codes. It turned out to be intake manifold gaskets were bad. With the engine running spray some carb cleaner on the intake where it bolts up to the heads and listen for the engine to speed up. If it does you've got a leak. With mine I couldn't find the leak with the carb cleaner but after I replaced the gaskets the problem was solved. Hope this helps.
Jan 18, 2012 | 2000 Chevrolet Silverado 1500
Were is the map sencer located on a 1991 honda accord?
The map sensor is located on the passenger side fire wall
Dec 24, 2011 | 1991 Honda Accord
I have a 94 chevy lumina it idles high in park and when i put it in gear it stalls i have replaced (one of the o2 sencers, egr vaule, map sencer, trottle sencer, and another sencer but not sure what it is....
throttle position sensor can cause the high idle as will a hole in the egr valve tube as far as stalling as soon as u put in to gear could be torque converter not unlocking but id check the egr tube first
Jun 07, 2011 | Chevrolet Chevy Cars & Trucks
Where ist he maf sencer located on a 94 firebird 3.4l v6, i cant find any good info on google, like a pic or something?
I'm pretty sure the MAF is sandwiched between the Air Filter Box and the intake tube. Should be 4 screws.
Jan 06, 2011 | Pontiac Firebird Cars & Trucks
Ware is the map sencer located
At the passenger side end of the upper intake. Between the coil pack and the alternator.
Nov 17, 2010 | 1998 Buick Park Avenue
Runs rough too rich replaced oxy. sencer &temp. sencer.1987 suburban 350 .thinking about changing maps sencer next
That may help. Also check for fouled plugs. Also check the fuel pressure regulator on fuel rail, check for vacuum at the regulator.
Mar 06, 2010 | 1987 Chevrolet Suburban
Car wants to stall changed injecter,egr valve iac
hi
check the all vacuum pipes is their any leaks.
Feb 21, 2010 | 1994 Saturn Sl
Where is the map sencer located
To install:
  1. Make sure that the manifold is clean.
  2. Install sensor to manifold.
  3. Tighten screws.
  4. Connect the electrical connector to the sensor.
  5. Connect the negative battery cable
  6. Install the air cleaner cover.
    0900c15280225b0f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig.
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?partName=Manifold+Absolute+Pressure++MAP++Sensor&pageId=0900c15280225b0e&partId=0900c15280225b0e#hd1-1-2
Jul 14, 2009 | 2003 Chrysler PT Cruiser
Catback Exhaust 96-00 Chevy Cavalier Z24 2.2L 2.4L 2DR 4DR Logo
55 people viewed this question
Top OBX Foam Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an OBX Foam Vehicle Part and Accessory Expert? Answer questions, earn points and help others
