Question about Hoover Washing Machines
How do I fix a E15 on my hoover DYN9166P - Hoover Washing Machines
My tumble dryer keeps stopping and showing E15 in the middle of a cycle I've cleaned the air filter it's hoover 8kg
E 15 is an error message. Turn the machine off from the socket. Unplug it. Change the cycle to a different start point. It may have a worn bearing because of overweight and resists the weighthe bearing because of damage. The weight is important to regular functions.
Jan 15, 2018 | Hoover Dryers
I have E15 on my hoover tumble drier. any ideas what it could be?
faulty heater element and or thermostat........cheers
Oct 06, 2016 | Hoover Dryers
Error code e15 showing
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Dec 19, 2015 | Hoover Washing Machines
Hoover fault codes
Return to manufacturer for repair or replacement within 1 year!
Sep 02, 2014 | Washing Machines
How do i open my hoover eco technology door when it wont open and comes up with the code E15
That means a sevies tech has got to come out an unlock
it the main board is bad these front loaders
are bad about this they will lock up all your
cloths
Jun 13, 2014 | Zanussi ZWD1470W Front Load Washer / Dryer
E15 error hoover
my washing machine HOOVER DST 10146 P is showing error code E15 what does it mean and how to fix it?
Jan 03, 2014 | Washing Machines
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Dec 20, 2010 | Washing Machines
Washing Machines Logo
244 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
