Question about Sony VAIO VGC-LS20E Notebook
When i start my computer it comes on like its suppose to then the screen goes black if you take a flashlight and shine it on the screen you can see that the computer is running you just cant see it without a flashlight shining on lit
  • Sony Master
  • 5,127 Answers
This is a sign of a backlight problem. First, check to see if you can increase the brightness by pressing the Fn and F6 keys at the same time. The F6 key is in the row above the row of numbers. The Fn key is on the lower left hand side of the keyboard between Ctrl and the key with the Windows symbol in a circle.
If the brightness won't change, then you would need to carefully disassemble the all-in-one to reach the LCD panel. You need to avoid breaking any of the small wires inside the unit. The panel has several parts held together by tape. The backlights are usually on the edges under the tape and a reflector. Often, they are molded into the frame; you need to use a Dremel or similar tool to free up the parts from the plastic frame. Make sure to note the way all the pieces fit together before taking things apart. Since this all-in-one has a 19" monitor, it probably has the backlights in pairs. Then remove the backlights and replace them with ones that match for length and diameter. http://lcdparts.net/ is one vendor that sells replacement backlights. This site also has installation details. There are other sites that show the steps involved as well.
This is significantly cheaper than trying to get a replacement LCD panel. A new LCD panel might cost more than half the price of a new all-in-one.
Good luck. I hope this helps.
Posted on Jul 31, 2013
Monitor has power. Will come on very briefly and the go to black screen. Can turn power off and back on and get the same above result.After a 2-3 hour period may come to life...may not.
It appears as if the monitor's back lighting is failing. To test the theory, take a bright flashlight and shine it on the lcd monitor screen when it goes black. If you can see the images that were on the screen before it went dark while shining the flashlight on the screen, then the back lighting is failing. Depending on the monitor, it could have florescent or L.E.D. back lighting, but it's usually more economical to simply replace the monitor with a new better performing monitor, than to attempt repairing the back lighting on the failing monitor.
Dec 01, 2010 | Samsung SM225BW 22 inch LCD Monitor
Flickers, then goes black. If you shine a
It is definitly an inverter of the monitor take it to the nearest service center and they will replace it.
May 08, 2010 | Toshiba Satellite A205-S5812 Notebook
Monitor goes black when i turn it on
just a big hardware problem in your monitor
Sep 23, 2009 | Samsung SyncMaster 216BW Monitor
Screen goes black after a few seconds.
when the screen goes black shine a flashlight on it. If you see a dim image the back light needs to be replaced. Otherwise check the inverter as that may be causing the problem as well.
Sep 07, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Tv picture comes on for a second then goes black
this is due to (i suspect)the tiny halogen lights that sit on top and botton inside the screen i know that because i have a computer monitor with the same problem it is really easy to desemble the whole electronic, the real problem is how do i get those lights!
Aug 11, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
Monitor went black in seconds
oboy, One thing to try is the flashlight test. and get backto me with your findings. Tell me, does this lcd show a nice display only for 1-2 seconds and then a black screen when connected to a fully booted PC with Windows desktop displayed? Shine a bright flashlight 1-2 inches from panel and tell me if you see the WINDOWS START Button at lower left of screen even though screen is black! Get back to me if you can. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Apr 04, 2009 | Niko 1920W Monitor
Monitor goes blank less than a second after turning on.
there is an hardware issue in your lcd it needs to change one of the capaciter please take it to a lcd technician
thanks
Jan 24, 2009 | Acer AL1715 17" LCD Monitor
Screen goes black
Hai,
Do you see any dull image on the screen ?
If yes the inverter Card/Backlight of the screen is having problem.
Regards,
Aby
Dec 22, 2007 | Rosewill R900J 19" Flat Panel LCD Monitor
Sony VAIO VGC-LS20E Notebook Logo
29 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
