Question about Car Audio & Video
How do you install a metra mdf-5812-2 radio - Car Audio & Video
Radio Shack CAT NO 43-5812, do you have a manual for answering machine
Radio Shack has the documentation for the 43-5812 (SP-812) Digital Answering Machine here: http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=43-5812&Name=Telephone%20Answering%20Devices&Reuse=N . These are all text documents and the English version of the documents are on the right hand side of the page. The direct link to the regular operation section is http://support.radioshack.com/support_phones/doc39/39765.htm . The documentation for remote use of the answering system is here: http://support.radioshack.com/support_phones/doc39/39766.htm . A trouble-shooting page and other documents are also available.
I hope this helps.
Apr 23, 2017 | Radio Shack Radio Communications
How do i replace my stock radio for a after market radio in a 1995 lexus sc400
There are several steps:
1. Take out the center cup-holder (it pops out with a little tug upward). unscrew the 2 screws.
2. On the shifter (lower part) there is a cover that covers 2 screws, unscrew and remove the shifter knob.
3.Take a pick tool and lift the shifter bezel console (black) it also pops up.. there are 3 or 4 connecters (disconnect with a small flat head screwdriver)
4. Once the shift cover is removed, there are several screws and tabs holding the bezel trim down unscrew the screws and lift bezel trim up,
5. Disconnect the ash-tray (blue connector)
6. Disconnect the hazard signal control , volume control connector and the climate control connector.( On the left side)
7. There are 4 screws holding the the radio and climate unit cage to the dash frame. (unscrew)
8. Now it gets a little tight, pull the unit towards you slightly and disconnect to connectors for the climate control unit (on top) and the factroy radio (on the bottom).
9. Next remove the radio and climate control unit from the cage(screws on the sides).
10. Next you will need a new cage: Metra 95-8157B Double DIN Installation Kit for 1992-2000 Lexus SC300 and SC400 (Black)
by Metra Link: http://amzn.com/B001TJG7SA
11. You will need the following harness: Metra 70-8112 Radio Wiring Harness for Toyota Amp Integration 15 Pin by Metra
Link: http://amzn.com/B0002BEUBW and/or Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker by Metra Link: http://amzn.com/B0002BEQJ8
12. Match the wires according to the metra kit and new radio instructions.
13. Next follow instructions in reverse for re-stall. GL.
Feb 09, 2014 | 1995 Lexus Sc 400
Doesn't fit pyle
Your supplier of the kit can answer that one.
murf427
Aug 01, 2012 | Metra 2004-2009 Ford Radio Double-din Dash...
My Emerson 5812 Boombox will not turn on all of a sudden. I just bought it a couple months ago and it will not power on.
If its still under guarantee then take it back to the shop if you have the receipt. If not then it could be something as simple as a little glass fuse inside the boombox.
May 21, 2010 | Emerson (PD5812) Radio/CD Boombox
What do i need to install after market cd player in my 2004 GMC Sierra?
The sad part about installing into alot of GM cars is that the Harness is about $100 bucks
You need a Metra GMOS-01
You need a metra 40-GM30 ( Antenna adapter, since the stock plug wont plug into after market radio)
And a Metra 99-2003 ( dash kit
Apr 06, 2010 | Pioneer DEH-P2900MP CD Receiver...
Im having trouble installing my double din alpine deck in my 2008 f-150. At one point I had everything installed and ready to go, But when I went to open the face to put a cd in the the monitor had trouble...
According to Metra you are using the right dash kit you just need to figure out the alignment for the radio. It will take some time but you will get it. Try to pull the head unit forward on the mount kit for the clearance.
Sep 25, 2009 | Alpine Car Audio & Video
How 2 remove d radio from 2000 corolla to install a cd player
you will ned some accessories to put it in properly.
1. 99-3413 metra install braket. will ease the mounting.
2. 70-1761 metra wire kit will allow you to fly through the hookup.
you will be able to get these parts at your local stereo install shop.
when you purchase the mounting kit the instructions on how to remove and reinstall your cd player will be in the instructions. illistrations and all.
Aug 28, 2009 | AviStart 5303 2-Way Security / Remote...
Factory Amp
I assume you used the correct Metra plug (70-1878) to install the radio. Ensure the blue and white wire on the Metra is attached to the blue and white wire (or solid blue) on the Sony. This will provide + turn on voltage to the factory amp.
The other good possibility is that the Metra harness has a black and a black and white set of wires both must be ground.
Lastly the Metra harness does not provide these( -) grounds, they are supplied by the braided strap . or the single wire that was attached to the back of the Jeep radio.
Jul 22, 2008 | Infinity 475A Car Audio Amplifier
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
