I have a jmb 32inch tv when i connect my headphones and mute the tv no sound comes out the headphones.when i unmute the tv the headphones work again.please help
5 Suggested Answers
likha
  • 790 Answers
SOURCE: Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Posted on Sep 14, 2007
SOURCE: audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Posted on Nov 10, 2007
  • 17 Answers
SOURCE: After using the headphone jack on the side of the
try changing the sound output sometimes the tv will change to headphones only so you have so change it back to the tv speakers your owners manual should tell you how to do this
Posted on Apr 15, 2009
  • 4234 Answers
SOURCE: My deaf father has been recommended to use
This is not a typical setup for most TVs. There are ways around it though. If your set has a set of audio output jacks, than those can be used to power a separate sound source for the headphones. There are adaptive listening systems available for this purpose what use either infra-red transmitters or RF transmitters to matching headphones. The key here is whether or not the TV has the audio output available.
Please check that and update this with what you find and I'll try to provide a solution within the context of your specific set. Post the TV model number too.
Thanks,
Dan
Posted on Nov 12, 2009
I am having problems with our daughter's tv. The volume isnt working now even though the picture is fine?
Have you looked at the headphone jack? Sometimes a set is left plugged in and sound wil not come out of speakers.
Also, look at cable box. It can sometimes have a separate volume control.
last, if you plug in a set of headphones and you hear sound, pick up a pair of inexpensive powered speakers and use those.
Jul 10, 2014 | Bush 5693D 24" TV
Turn off mute mac
connect a set of headphones or external speaker to see if it makes any sound if so it may be a bad speaker.
Apr 05, 2014 | Computers & Internet
Hi my sound as stopped working on my 40 inch jmb tv the buttons working turning up an down no sound tho
Check its speaker first. If found OK, check and replace damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 28, 2014 | Televison & Video
The Sound has stopped working on my telly
if you have sound from the headphone jack the sound circuit is good--audio headphone jack when inserted cuts off internal speakers--it could be 3 days old and have a problem with the jack.
Jun 07, 2012 | Televison & Video
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
Audio coming when connecting headphones but not coming out of speakers for ibmt41thinkpad please reply on ibm thinkpad t41
There are volume buttons above the key pad - a volume up, down and mute button. Have a check with those once. Unmute or increase the volume and check
May 20, 2010 | IBM ThinkPad T41 2373 Notebook
No audio
went into setup, tv and kept hitting the mute then unmute it finally took. Not sure what was wrong with it since I had already done that several times. The two audio outputs on the side of the tv do not work like it says in the manual for surround sound. Its definitely a cheap tv.
Jun 21, 2009 | Olevia 227-S11 27 in. LCD TV
Thinkpad R51 Audio Driver
I had this exact same problem. Try this:
Above the keyboard are three hard keys for volume (down, up, and mute). The mute button only mutes, it does NOT unmute. To unmute, push the volume up button a few times. Now try your sounds again.
I was very confused because the hard mute key does not affect the GUI at all (you don't see the little speaker with the red x in the notification area). Hope this helps!
Jun 17, 2009 | IBM ThinkPad R51 Notebook
Televison & Video Logo
Top Televison & Video Experts
