Re: PAPER JAM INDICATED BUT CAN''T FIND ANY PAPER JAMMED
Check the system is ok and the rollers are not jammed and maybe take the cartridge out and take out the roller then reinsert and if that doesnt work reinstall its program to ya comp thanks
Hi there, My epson printer showed a paper jam light although no paper was visible. I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily. ***NO RESPONSIBILITY ACCEPTED FOR LOSS OR DAMAGE IF YOU USE THIS SOLUTION I USED TO FIX MY PRINTER********* i cut an A4 sized square of cardboard from a cereal packet. I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam. This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing. The cardboard pushed the tiny piece of paper out. Turn off the printer and then turn back on - you should find the printer now works. I also found it helpful to clean the feed path and to try and keep dust from settling in the printer. If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing. Hope this has helped.
Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
Fixing a printer paper jam When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
Turn off the printer.
Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
Remove
the printer. If the stuck paper is visible manually remove it.*
Open
issue still persist and you see no paper that is stuck in the printer
it's likely your printer is experiencing another hardware issues and we
suggest contacting the printer manufacturer for additional assistance and/or repair.
To manually remove paper pull on the paper with both hands being
careful not to tear the paper while pulling it. If you're unable to get
to an edge of the paper that allows you to pull it you may need to
manually rotate the gears that feed the paper through the printer.
Remove
Open
Preventing a printer paper jam As
mentioned earlier it is inevitable that you will encounter at least one
paper jam during the life of your printer. However, if you're
encountering frequent paper jams following the below steps can help
prevent paper jams from occurring.
If your printer has a
paper tray do not fill the tray to capacity. If you're encountering
frequent paper jams reduce the amount of paper you place in the tray
each time it is filled.
Make sure you or the tray feeding the
paper into the printer is aligned properly and/or the slider used to
hold the paper in place in the tray is snug with the paper. Many
printers have sliders that allow different types and sizes of paper to
be fed into the printer. If the slider is not properly positioned it can
cause paper jams.
Use standard office paper; folded paper,
paper with labels, and specialty paper such as hard bound paper can
often cause paper jams. If you're uncertain with what type of paper you
should use with your printer your printer documentation will list the
types of paper compatible with your printer.
Do not mix the
types of paper you're feeding into the printer at one time. If you need
to change the type of paper or size of paper being used removed any
other paper currently in the printer before inserting the new paper.
Examine
the printer for any previous stuck paper in the printer. Previous paper
jams, torn paper, printing labels or other foreign objects in the
printer can cause reoccurring printer jams.
Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Please post your feedback and Vote if the poblem resolved as per your satisfaction.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
1.unplug the power from printer to reboot it 2..if the lights flashing like woof said check for jammed paper or sticky label inserts in the back door of the printer. 4.clean the circuit bit of the cartridge (sometimes a thin film of ink can stop the circuit)
There must be apiece of paper in one of the cogs do atthe bottom of where the paper is inserted. Try removing the covers and seeing if you can get it if not try using paper feed button with no paper.
