Question about Hayward Navigator Pool Cleaner
Hoses are getting all twisted up. there is no clog and the hoses are stored in a straight line. Is the neck at the top of the vacuum not turning? if so, what causes this?
Look on line for a pool hose swivel. your hose should be 1 1/2 as a norm . they don't know what a swivel is at all the pool stores I stopped at. should be able to improvise I stretched my hose out on the bricks for 2 days in the florida heat. it seems to have helped. but still look for the swivel connector,cut into hose about 3 ft. at either end you chose to mount the swivel. good luck. amf
Posted on Aug 18, 2013
How do I clear a blockage
Try removing your hose from the bag housing (pinch retaining ring and pull out) and re-inserting in reverse order. Turn the vacuum on and suck the clog into the bag. This will usually clear a clog from the hose. If the clog is in the power head (base), you can usually access it from the top side of the swivel neck or the orange access door on the bottom of the chassis.
Sep 23, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
My vacuum shows a full bag after 20 seconds of running. Put a clean bag and the same thing happens.
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Mar 31, 2011 | Electrolux Epic 6500 Vacuum
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
Mar 11, 2011 | Electrolux Vacuums
Does not turn on epic 6000
Feb 27, 2011 | Electrolux C101 Bagged Canister Vacuum
I install a new bag and the bag light comes on and the unit turns off.
Feb 19, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
The bag light turns on and the vacuum turns off within seconds of turning the vacuum on even with a brand new bag
First try turning dial on top of the machine so the arrow lines up with the smallest dot.
The most likely problem is clogged, worn, or broken control valve assembly (CVA). It could also be clogged tubes to the CVA. This is usually caused by using "made to fit" bags rather than the genuine bags made by Home Solutions. The vacuum would need to be taken to an authorized Aerus Electrolux store for repair/replacement. Generally, if this is the problem, the interior of the vacuum, including the motor, needs cleaned as well.
Some other simple things you can check are:
Dirty afterfilter. This is located on the exhaust hole on the back of the vacuum. To access, press in on tab at back of the exhaust cover, lift cover from the back, and remove filter. If the filter is dark, it is clogged with dust particles and needs replaced. Turn vacuum on and run it for awhile. If it continues to run, this is the problem.
Another potential cause is a clogged hose. Disconnect hose at both ends. Drop a coin down one end and lift that end to allow coin to drop through the other end. If it does, fine. If not, connect hose to the exhaust port, place other end into a large garbage bag, or into the in port of the vacuum, and turn on. This almost always clears the hose.
Check the elbow of the power nozzle where the hose connects. Drop a coin through here to check for clogs. If there is one, it can generally be cleared by pushing it toward the brush with a wooden spoon handle, or similar blunt object.
For nearest store, follow instructions at below link.
Feb 12, 2011 | Electrolux Lux 5500 Canister Vacuum
Says the bag is full when it's not
Feb 11, 2011 | Electrolux Epic 6500 Vacuum
Vacuum does not have power and indicator light that looks like a plug is lit in red or orange
This light is an indicator that the vacuum is getting power, so there's another problem.
First, turn the dial on top so the smallest dot lines up with the arrow. Then check the after filter beneath the tool caddy. Remove and/or replace if it's dirty. Try the vacuum now. If it still doesn't work, continue.
Turn vacuum off. Detach hose. Turn vacuum on. Does it run without the hose? If not, the control valve assembly inside the vacuum is bad and needs replaced. If it does run without the hose, place palm of hand over opening. Does it run? If it shuts off at this point, the tubes connected to the CVA are probably clogged and need cleaned. Either of these repairs need to be done by an authorized Aerus Electrolux service tech.
Other problems may include bad switches, broken/bad wires/connectors. There is the possibility of a burnt out motor, but it's not likely. The only way to get a definite diagnosis is to take the vacuum to an Aerus Electrolux store and have the tech troubleshoot it.
The nearest store can be found by clicking "store locator" at the bottom of the page on the site below.
aerusonline.com
Jan 04, 2011 | Electrolux Epic 6500 Vacuum
2100 comes on but will not keep running, I have changed filter and bag.
The dial on top of the machine should be set about mid-point. If it is, then turn until the small dot and the arrow are lined up. If this doesn't help, turn all the way around so large dot and arrow line up.
2. Detach hose from vacuum. Turn on. If it continues running, place hand flat against the intake. If it shuts off immediately, there's probably a problem with the "Control Valve Assembly". This is a part that can be purchased at your local Aerus Electrolux store. I highly recommend allowing them to replace it rather than trying to yourself.
If you don't know where the closest store is, go to aerusonline.com, click on "store locator" button at bottom of page, type in your zip code and click on the find store button.
If your vacuum runs fine without the hose attached, then check hose and power nozzle for a clog.
Sep 30, 2010 | Electrolux C101 Bagged Canister Vacuum
Clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Hayward Navigator Pool Cleaner Logo
208 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
