Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Scooter wont run unless it is physically being charged
    Habit-Forming:
    New Friend:
  • 88 Answers
I think your batteries have died. Are they 2 years old or more?
Posted on Aug 02, 2016
Can I charge the battery on my centurion mmx scooter with the battery off of the scooter
the charger off a scooter is for 24v system. in your application are you sure it is not 12v or a 36v system? Do not try unless you are sure! Don't want to break grandmas charger.
Nov 18, 2015 | Health & Beauty
I put oil in my scooter cause it was low and now it wont start
Hi Jason,
You may want to perform a full oil change and go again. In the process. Could your battery have a low charge or need water? If the scooter cranks. Also try to kick start manually? To over fill oil is not symptomatic; unless back pressure has built up for another reason.
Fare Well..
Dec 12, 2014 | Motorcycles
Scooter not charging when plugged into the charger
measure the voltage of the batteries thru the charging socket of the scooter, the outside 2 pins.
Sep 20, 2014 | Health & Beauty
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Celebrity x scooter wont charge
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Save as a PDF File + Print for future,hope this has helped,Colin.
Nov 22, 2011 | Health & Beauty
My scooter wont charge. Light stays red for days of continuous charge. wont run at all. only nine months old.
Sounds like the batteries are dead.
Nine month is reasonable depending on how the batteries are use considering they are lead-acid batteries.
Lead-acid batteries get PERMANENTLY damaged when you drain them all the way. It would be better for the batteries if you only used them half way can charge as soon as possible after each and every run. They like to be kept fully charged at all times.
Sep 06, 2010 | Razor E300 Scooter
My electric scooter stopped running. it turns on but wont "go"
Make sure battery is freshly charged and is holding the charge would have to test battery with multi metre. If its holding its power then first i would go to the switch that you use to make the motor go.
May 30, 2010 | Razor E100 Electric Scooter
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Feb 07, 2009 | Pride New Mobility Victory XL 4 Wheel...
Battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Nov 21, 2008 | Sonic 3 Wheel Scooter
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
59 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
