Question about Health & Beauty
I have a Jazzy Select power chair the is running very ruff. It will run good for about 10 minutes then it slows down and will not steer and then just stop. i shut it off awhile then it goes again but not far then stops and goes have to keep shutting off and starting again. I know its not the batteries they are good just got new ones about 3 month ago. Also when I shut it off and turn back on the power control lights flash 2 times then just stay on as usual.
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
  • 131 Answers
SOURCE: '99 chevy Silverado Z71,5.3 engine.....will not rev when hot.....
try replacing your EGR Valve, or your Oxygen Sensor
Posted on Feb 10, 2009
  • 188 Answers
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
  • 71 Answers
SOURCE: 1986 Yamaha Radian stops running after 20 minutes
Sounds to me like it could be a few things... pretty interesting that it runs and shuts down...sits for a little while then fires back up. Could be something as simple as a bad ground.. maybe it needs cleaned.. if the ground is making very little contact.. the bike would run bad, and because its direct current it has to flow. The metal in the motor frame etc will hold so much DC current.. but *** soon as it load up the bike would stop sparking. Let it sit for a while, DC trickles into the battery through the slight contact, bike fires back up. OR could be bad venting of your fuel tank, or a partial clog at the pet ****.. the first is pretty easy to check, open your fuel cap and start the bike..if it does the same thing then its not a vent problem. One thing that does happen on the Radian, is the reserve fuel screen inside the tank comes loose, and then everything inside the that has built up over the years either partially clogs the pet ****, or the hose, or both. Take the tank off, pull the pet **** off..if it still has two intact tubes with good screens..you probably don't have any junk in your line..but I would pull the line off and blow through it any way... it could be some type of blockage, when the bike sets the fuel seep through, but when it runs it eventually creates a vaccuum that stops the fuel flow. Those are my two first thoughts... good luck!!
Posted on Jun 07, 2009
  • 3 Answers
SOURCE: my wifes strider chair runs
Ztarg is the Medline Industries approved service and parts distributor for the Strider and Gemini Scooters.
Their contact information can be found on their website www.striderscooterservice.com
Posted on Jul 09, 2009
Is there a way to increase the speed on this chair
Yes. Change the potentiometer behind the throttle lever. It's probably 10 ohms. Try a lower resistance pot. It will run the battery down quicker though.
Jan 07, 2016 | Pride Jazzy Select 6 Indoor Power...
How to unlock Jazzy Select chair so it can start up and run
Turn on the PWC
Push the joystick forward and hold for 2 seconds or until you hear a chirp.
Push the joystick backward and hold for 2 seconds or until you hear a chirp.
Release and there should be a long beep tone, signaling that it is unlocked. Since there are different joystick controllers on these chairs and I don't know exactly which one you have this is my best guess.
Dec 20, 2015 | Pride Mobility Products Jazzy Select
How long can i run chair on one charge'
With new, fully charged batteries, you can get a good 8 miles at full speed with a normal weight load on the chair. The chair goes about 4-5 mph, so an hour and a half or more at full speed on level terrain. Be sure to always recharge daily, keep the chair on the charger when not in use(batteries will die if you don't)and avoid running the batteries all the way down....try to stay in the top 2/3 charge range and you will get more life.
Apr 27, 2014 | Pride Jazzy 1103 Ultra Indoor Power...
Why is my merits DL 5.2i stuck in low speed ?
You may have a thermal rollback issue. Try charging the chair overnight and leave the controller on while charging. This will give the control module/joystick time to reset themselves. Thermal rollback happens when a certain temperature in the motors is reached. The system shuts itself down to protect from damage.
Apr 26, 2014 | Select Jazzy Used Electric Wheelchair
Jazzy select is swaying side to side when going forward like it has too much play in the joystick
Check your tire inflation and treads to make sure they can grip the floor/ground without slipping. Make sure that any keystock/keylock needed is installed on the axle, sometimes they slip out. Are your batteries fully charged and in good condition? Are you over the weight limit for the power chair?
Is there any noise or vibration coming from the power chair as you operate it? A grinding sound may indicate bad bearings in the caster wheels and cause problems in steering. A chirping sound may indicate a bad motor, they may be losing power and are not able to move the power chair evenly.
If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 28, 2010 | Pride Jazzy Select 6 Indoor Power...
Can the speed of the Jazzy Power chair be increased beyond the setting on the armrest remote controller?
Make sure that your tires are properly inflated and that you are not carrying more weight than the power chair will allow and that your batteries are fully charged.
If you got your chair second hand, sometimes the previous owner has the technician change the controller settings to "dampen" it to slow it down to allow them greater response time and control. The technician can reprogram the controller to take it back to 100%. If you got the power chair new, it should be at 100% already.
Take it easy, HotRod. It's a medical device, not a car!
Jul 20, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
My father has a jazzy select power chair. The spe...
You will have to take it to a mobility dealer to have it programmed
May 14, 2010 | Health & Beauty
Just bought 2nd hand jazzy select 6 ultra v v slow !!
The unit can be programmed to run faster. Stop in to the local powerchair dealer in your area. Very quick and inexpensive fix. I would charge you only for my time. About 10minutes max.
May 15, 2010 | Pride Jazzy Select 6 Indoor Power...
Jazzy Power select 7
Put the chair in free wheel mode and then back again and then turn the chair off then on again. Sometimes the chair will get out of gear just a littel.
Oct 07, 2009 | Pride Jazzy Select 6 Indoor Power...
Health & Beauty Logo
61 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
