Question about Vehicle Parts & Accessories
2000 Ford Taurus wont start. Turning key feels loose, no resistance. No click or anything. Battery is fully charged and the inside accessories word. There is a new key lock cylinder (replaced after th
The picture has the explanation. I was having some trouble typing in the given box earlier.
  • 116 Answers
Two reasons:
1. Internal ignition lock because of the relationship between the use of time, resulting in poor contact, can be replaced.
2. The vehicle line problem and needs to repair lines
Hope it useful
Maybe you can use some tool to check your car or send the car to repair
Car Diagnostic Tool
Posted on Aug 18, 2016
  • 430 Answers
Test voltage on starter for 12 volts and check for loose wiring or damage wiring at or near starter area.
Posted on Aug 13, 2016
    New Friend:
    Problem Solver:
  • 8 Answers
Maybe the ignition control switch or between the steering wheel and the colum there is a comtrol unit I for get what its called be care full theasb is rite there buy the book for your car it helps autozone
Posted on Aug 04, 2013
Drove my 2000 Ford Mustang to the store, parked & locked it. Came back out 15 minutes later, unlocked it, got in & put my key in the ignition. The key & ignition switch turned all the way over with no...
Could be a bad battery or your battery cables could be loose or corroded so there is little power getting to the starter.Check all battery cables at both ends and might even have to take the cables off the battery and clean the connections hook up to the battery.
Jan 05, 2015 | 2000 Ford Mustang
Why wont my car start
Possibly a battery cable terminal or the connection at the starter.
Sometimes a loose or faulty wire can barely work until a load is put on it then it just shuts down. Test power flow at starter before and after turning the key. Replace battery cable ends and if the problem persists, replace entire cable.
Aug 01, 2014 | 2003 Ford Taurus
2003 Ford Taurus will not start. Have tried jumping the battery but still nothing. When turned on, all dash lights come on and then there is a click sound when we try and turn it over.
2003 taurus not starting the lights on dashboard not coming wont go up and wont crank ..anyone know what to do ..please
May 14, 2012 | 2003 Ford Taurus
What could be the problem if my car will not start but my battery charge is good?
relay,solenoid,bad ground,fuseable link by battery,bad terminal,car not totally in park,loose connection,starter even use these suggestions and the process of elimination and you should be runin in no time
Mar 26, 2012 | 2000 Ford Taurus
2000 ford taurus wont start. When the key is turned I have no dash lights, or power to the accessories that run through the ignition. I changed the ignition switch today. Thank You Chris
Is your dome light coming on? do the power locks work?
Your battery may be dead, or you may have blown a main fuse (under the hood)
Mar 09, 2011 | 2000 Ford Taurus
2000 ford taurus lx wont start
Feb 27, 2010 | 2000 Ford Taurus
Car stopped while being driven. wont start now. just make a clicking sound when you try to start. looked underneath, there is a whole about 1 1/2 inches in diameter which appears to be broken from a cover...
sounds like your diff has exploded in your gearbox there for not allowing the starter to turn the flywheel id advise you to take it to your local garage and get them to look but sounds very serious.
Oct 28, 2009 | 1996 Ford Taurus
Car will not start.
Next step is checking the battery, or replacing it.
After that, check that the 'security' key or whatever is used on that vehicle isn't messed up. Might be a fuse for that as well.
Jun 22, 2009 | 2002 Ford Taurus
2005 ford taurus. Remote entry wont work theft light keeps blinking when key is engaged
HI, I'm reading your problem,
Let me explain something about your car.
2005 Ford Taurus, The key on that car has Chip inside of the key and receiver on the ignition switch,
Check if the key you are trying to use is Black and has a plastic head.
If not you need a key with that characteristics.
But if you have the right key, Remenber if you had drop on the floor, or hit with something,
Because some times they come damaged, with insignificat thins.
Remenber if you left the key close to a magnets like speakers.
If nothing aply at your case, you need to call a place Aloha Smith, they have the computer to program or reprogarm your key. IF not you can't start your car.
OK.. I hope this information work for you.
Thank's for submit yous question on
Jul 10, 2008 | 2005 Ford Taurus
Vehicle Parts & Accessories Logo
118 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
