I have a Kenmore 110.21302010 that is less than 2 yrs old. It will go thru all cycles, but after spinning the clothes are still soaked. I have to remove most of the clothes and leave 3-4 items in and manually put it on drain/spin in order for the spin cycle to leave the clothes ready for the dryer. I would like to attempt a fix, but don't know where to start. Any help is appreciated. THanks!
4 Suggested Answers
  • 1122 Answers
SOURCE: kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Posted on Dec 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: Drum not spinning during some spin cycles
Replace the direct drive coupling.
Posted on Mar 23, 2009
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Kenmore 23012 / Clothes still wet after spin cycle
Remove end caps from console (put fingers behind top and pull towards you. small flat head may be required). and the 2 phillips screws behind them. Pull console towards you and up, it wil flip out of the way. Unplug door switch connection on top rear right of cabinet (3 wires). Put flat head STRAIT DOWN into brass looking clips and push forward. They'll pop out. Lean cabinet towards you and shine flashlight inside. Look for oil splatter about 8" up from bottom. If there's oil, then the trans has leaked oil into the clutch and it's slipping. Repl. transmition and clutch assy. If you see oil, it's cheaper to buy new washer. Trans and labor is about 400
Mar 17, 2009 | Kenmore 23012 Top Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore washing machine
remove top panel where switch is. replace switch behind control knob. this switch wears out in time. the wires just plug in so no soldering. very simple.
Jan 28, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine spin cycle
if a second spin dries the clothes as it should then i would be looking for blockages in the pipes that either go to the pump from the drum, or go from the pump to the outlet connector on the wall or sink, hope i have been of some help, if so please rate me, thank you
Oct 06, 2007 | Kenmore 22622 Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
