Question about Clarity XLC 3.4 DECT Amplified Cordless Phone
Clarity xlc 3.4 lcd screen is garbled. is the battery low, or is it something else?
No dial tone
Broken line to the phone I would say in the phone pit outside..ringnyournprovider to check the line.
Feb 01, 2014 | Clarity XLC3.5HS Extra Loud Cordless...
Tip
When your screens blink.. What to do!
A lot of people have had the dreadful blinking of the screens. Whether it's only 1 screen blinking (upper or lower) , or both screens blinking..
I have a tip to help you diagnose the problem so you don't have to waste time trying to find out what's wrong with it, or waste money.
1.) IF YOUR UPPER LCD BLINKS
  • There is something wrong with your lower LCD and/or the connector on the board where the lower lcd connects to.
POTENTIAL SOLUTION
  • Open up your Nintendo DS lite system and clean the board with rubbing alcohol. Be sure to dry the board from excess liquid before re-assembling it. Use a FIRM brush. An regular toothbrush would not work as the bristles are not firm enough.
2.) IF YOUR LOWER LCD BLINKS
  • There is something wrong with your upper LCD and/or the connector on the board where the upper lcd connects to.
  • Follow the Potential Solution to #1
3.) IF BOTH SCREENS BLINK
  • 99.9% of the time, if both screens blink, your light is red. Which indicates your battery is low. Change the battery. If your system isn't charing your batteries correctly and/or you're losing battery power unusually quick, replace the charger.
  • If that does not work, send your system in for repair, as the charging port needs to be cleaned.
on Dec 31, 2009 | Nintendo DS Lite Console
Clarity XlC 3.4 amplified telephone not ring.?
tv lcd toshiba 19HV15E,layar1/3 ada garis2 vertikal,apanya yang rusak
Jul 09, 2013 | Clarity XLC 3.4 DECT Amplified Cordless...
Hello ! So my mobile phone is Sony ericsson W595..its problem is the screen even if i adjust the brightness it isn't bright enough as what i'm expecting ... please help me ..
Possible that the LCD is faulty or the power feed to the display is low. You can try and reset the phone by removing the battery . also check if there is any moisture in the phone or LCD.
finally check to see if the fonts and images can be reset to give better clarity on a screen saver..
Mar 29, 2011 | Cell Phones
How to factory reset akai ds8341 camera. I see garbled images on the 2.5 inch lcd monitor
Two ways... 1. Go into the camera menu and find "reset"...follow the on-screen instructions. 2.Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 23, 2009 | Akai DC6371 Digital Camera
Lg2234s monitor goes of blinking...cant turn monitor off (blue light remains off) then monitor turns on ..screen pic returns but is totally green, the OSD becomes garbled, if set to return to default then...
emale36, Could be problem with the "switch-mode-power-supply" inside the unit. If dc voltage rail is noisey or marginally on the low side of rated specification then strange things will start to occur on screen. Contact LG (Lucky-Goldstar) if unit is covered by warranty. The unit will need to be evaluated by technician. Visit YOUTUBE to see video clips of monitore being repaired by their owners. Read more of my profile responses to other LCD owners. 12fixlouie
Dec 06, 2009 | Computers & Internet
Webcam picture clarity
It can be bcoz of multiple reasons. First make sure you have good internet speed 512 kbps or above or it is also possible he is using low pixel camera.
Thanks,
Jul 10, 2009 | Logitech Quickcam Chat Webcam
Lcd clarity
they don't need time to settle down..
Nov 26, 2007 | Televison & Video
Clarity XLC 3.4 DECT Amplified Cordless Phone Logo
48 people viewed this question
Top Clarity Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Clarity Health and Beauty Expert? Answer questions, earn points and help others
