Question about Balboa Instruments Garden
Balboa control board #51421 locks up. Top panel indicates "fl" requires a recycle of the circuit breaker to reset. Spa will be fine for 5 or 6 hours and then it repeats.
  • Balboa Instr... Master
  • 1,631 Answers
Solid or flashing "Fl"?
Flashing - clean filter, most common problem
Solid - Replace the flow sensor/pressure switch
Posted on May 27, 2014
4 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
SOURCE: we have a 2004 Balboa
Understand that this information is beingprovided as-is and without warranty or guarantee. As with all electricalcomponents and devices, all work should be performed by a licensed spa or pooltechnician. Serious injury or death can occur if a component is improperlyrepaired or installed.
There are several reasons the breaker can trip. It could bea bad pump, bad heater, GFCI or wiring issue.... Typically unplugging eachcomponent will help isolate which component is causing the trip. It is rare fora board to cause a breaker trip, so if all components (including both legs ofthe heater) are disconnected and the breaker continues to trip then you move onto wiring or the GFCI.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Posted on Sep 12, 2011
uspartscente
  • 717 Answers
SOURCE: breaker tripping
This could be a heating element issue. it could be a bad element. Disconnect the two leads going to the heating element and then turn the breaker back on. If it will run and not trip the breaker then you have found the problem.
On the heater tube there is a silver sticker that will have the information you need to identify what model heater you have and what the kw of the element is. It will either be 4 Kw or 5.5 Kw
You may contact us for more information about this or purchase the replacement element at www.uspartscenter.com
Posted on Nov 12, 2012
What runs on the .3amp fuse?
look on inside cover of control unit it has a schematic
Jul 04, 2014 | Balboa Instruments Pool & Spa
My Spa has a Balboa 500z Top side and control panel. It was running at 104 degrees and then one day it just shut down. The Circ pump won't start up at all and when I first turn on the power, I hear the...
Turn breaker power off. Verify now power to unit with volt meter. Most systems have in line over temp over current to protect circuit board and motor. Also the water level switch must be made to complete interlock condition. Check the heater coil for continuityas it may have opened. Check heater for continuity to each coil set. There is an interlock that is for diagnostics on start up that will prevent unit from starting. Look for any melted wires or components too. Always know and verify breaker settings. Verify your meter with known voltage reading first. Be safe my friend.
Jun 04, 2017 | Balboa Instruments Pool & Spa
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Balboa vs510s not heating
questions first:
is the heat indicator lighted up on the topside panel?
Is is tripping the breaker shortly after you turn the breaker on?
Is the tub running but not heating?
Rod
888-521-6183
Jan 31, 2013 | Balboa Instruments Pool & Spa
I have a balboa spa that is six months old and has been working fine. Went out to check it and it was cold and no readout on the display. Flipped the breaker and it went through its cycle and shut off...
It is possible that the board is bad. A loose connection orlow voltage issue may also cause this problem to occur. If the voltages arewithin the acceptable rand and all connection are tight then remove any accessoryequipment and restart the unit to see if the problem continues. If it does thena new board will probably resolve the issue.
You can find answers to common spa problems online at http://www.balboadirect.com/support.aspx
Hope that helps!
Apr 02, 2011 | Balboa Instruments Duplex Digital Panel 2...
Upper control panel flickers and will not allow me to control temo
how old is spa?
if new then circuit board maybe set on a mode setting that is used when being tested in the factory, locate dipswitch block on circuit board and move dip switch for MODE, should have a layout of dip switches on reverse of lid to control box
if older then you may need a new control panel (top side)
Adam Miller, Canadian Spa Company, UK
Aug 06, 2010 | Balboa Instruments Duplex Digital Panel 2...
My hot tub is getting power but I cannot get anything to run
you may have a circuit board error that is not allowing you to operate the controls or the top side may need replacing.
try locating the back up battery on circuit board and resetting it to restart your memory, does not always work but worth a try.
normally a J45 jumper, is marked on circuit board
Jun 21, 2010 | Balboa Instruments Duplex Digital Panel 2...
Where are you from?
Regards,
Ian.
Jun 07, 2009 | Balboa Instruments Duplex Digital Panel 2...
Open Questions:
Master spa legacy hot tub pumps stopped working after refilling it? my legacy inspire hot tub was fine before i drained it, then after refilling it pump 1 sounded like it was trying to work and never turned on, pump 2 was working, so i reset the power and let it go through prime mode and still pump 1 was still not working but make the same noise and pump 2 still worked, i then left it on overnight and in the morning pump 1 and 2 stopped working completely, made no moter noise at all, so i reset the power and still nothing, the balboa vs series controller box makes a click sound but wont let pumps work at all, now i get 5 different codes dr, sns, hfl, dry and ice, so we bleed all the unions to remove any airlock, then reset power and still the same click sound, then we emty the tub and started over again and refilled it with hot water and cracked all the unions and its still the same click, so we found an article about reseting the memory on the balboa controller and turned off power used the j46 jumper turned power on then off again then took off jumper then powered on again the the lcd panel said a bunch of reset numbers and worked but still the pumps dont work? i think the balboa controller is not letting the pumps to even try priming or to even try to work it just clicks in the balboa? is there a reset for the sensors memory?? ive replaced the heater and sensors last year so its not broken i just dont understand pump 2 was working then stopped and both completly stopped working overnight?? can someone help!!!!!
Dec 10, 2012 | Balboa Instruments Duplex Digital Panel 2...
Garden Logo
132 people viewed this question
Top Balboa Instruments Garden Experts
Craig Butler
Craig Butler
Delage guy
Delage guy
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
