Question about Garden
Broken cable, looking for replacement - Garden
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
If under warranty, go that route. If not, go to or call nearest lawn mower repair shop with model and serial number located under seat on riders and on deck or side of motor on pushes and have them look it up. Broken cable, looking for replacement - 4_1_2014_7_33_50_am.png
Posted on Apr 01, 2014
Upper latch is stuck and cab door well not open.
u will have to pull door panel off to look at linkage to upper latch if loose reconnect and open door, check for broken lock, if cable operated pull on cable with pliers to unlock, cable will most likely be broken on housing.replace cable. also check lock for foreign objects.
Jan 15, 2011 | 1998 Ford F150 Regular Cab
Camera FZ30, My ribbon cable to my LCD screen is broken. Where can I get a replacement ? Dont want to go to Panasonic as there prices are a rip-off...... Look forward to some positive feeback , Thanks
How did the ribbon cable get broken? Why don't you want a replacement from the manufacturer? How much do you really think you're going to save? Do you know how to replace the cable?
Nov 01, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
Broken gas pedal
Look at top of gas pedal arm area for a broken cable going through firewall area to throttle linkage. Need to replace, unless end just come off & you can re-attach.
Jul 08, 2009 | Ford F-250 Cars & Trucks
Audi a4 bonnet release mechanism broken
This can be over come by getting a pair of vise grips and gripping the cable that is sticking out and pulling it out, once you have opened it Do not attempt to close the hood without replacing the cable. You have maybe only one chance at this so if you don't succeed you will make it harder for a mechanic to fix it. a new cable is not to difficult to replace, buy the cable and housing replace both.
Jul 07, 2009 | 2005 Audi A4
2003 Stratus power window
Most of the time the regulator has to be replaced. if you take the door apart and take a good look at the regulator you will probably find a broken guide or fraid cable... something broken to make the cable jump off. (you may get lucky and be able to fix the old regulator...but in all the years i've been doing these i've only seen one that i was able to fix and not have to replace the regulator) Sorry I don't have a good pic of this regulator you can check with the dealer or local glass shop for an aftermarket or www.directauto.com
hope this helps
Feb 02, 2009 | 2003 Dodge Stratus
Broken handel (Wire snaped)
Cables Broken In your Handle ???? Please visit Repairyabuggy.co.uk as we specialise in the repair of Quinny/Maxicosi Mura/My 3 -4 Handles,Grips-Cables Repaired
Dec 16, 2008 | Quinny Buzz Jogger
Broken hood cable
Depends where cable is broken might be able to put vice grip on it and pull it from inside the car with the door open and you looking at the under dash lever. if can't then alternative is to lay on ground with a trouble light and look straight up under front where you think the hood latch is at if you can see the release then try to reach up and pry it enough to get hood to pop up on the safety then reach in and open it normally giving you time to see what is broken and to replace it. normally a book is available at the public library telling you how to specifically remove and replace broken and worn parts step by step, just find the proper book relevant to your model & make take it and see if it helps or not if it does your all set
Oct 10, 2008 | 1985 Cadillac DeVille
Cable antena ready input repair
Purchase replacement at radio shack, disassemble the tuner, and solder the replacement in. It is not a screw in.
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken RF Connector
you would have to get a new part for it. try looking online and out in your model number and put in rf connector needs replacing
Mar 10, 2008 | Apex Digital AT2002S 20" TV
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
