Question about Dell GX270 P4 256/40/48X/XPP/NONE (143657523) PC Desktop
01 ECLIPSE 2.4 GS I HAVE CHANGED EVERYTHING IN THIS CAR. CAMSHAFT SENSOR, CRANKSHAFT SENSOR,FUEL PUMP RELAY,HAD THE CAR FLASHED.TOOK THE FUEL PUMPOUT ITS WORKING. BUT HAD NO POWER TO THE PLUG IN ON THE FUEL PUMP THE INJECTORS ARE NOT GETTING FIRE TO THEM THEY NEED TO PULSATE. DONT KNOW WHAT ELSE TO DO?
    Scholar:
    New Friend:
  • 142 Answers
I would say do it all again. If you still have problems only thing you have left to do is replace the computer. If after that you still have a problem than take the car to the garage.
Posted on Dec 12, 2013
I have an issue with my 1995 Toyota Tercel DX with a 1.5liter engine. I have replaced everything from crankshaft position sensor, camshaft position sensor,coolant temperature sensor, Throttle position...
A lot of things have been replaced ... but there was no mention of checking any fuses or relays.
As an example ... if the fuel pump relay is bad then the car will crank over but not start
Jan 21, 2018 | Toyota Cars & Trucks
Where is the knock sensor on a Kia Sedona 2.9 diesel, 2004 LA
Here is the location of the "Knock Sensor" you requested, I hope it helps you. It is Number 17. for future reference here is the list of the others
1 = Camshaft position sensor (CMP)
2 = Crankshaft position sensor (CKP)
3 = Engine Control relay (EC) -engine bay fusebox/relay plate 1
4 = Engine Coolant temperature sensor (ECT)
5 = Exhaust gas recirculation valve actuator (EGR)
6 = Fuel Filter
7 = Fuel Filter Heater - in fuel filter housing
8 = Fuel Flow control valve - on high pressure fuel pump
9 = Fuel Rail pressure sensor(FRP)
10 = Fuel Temperature sensor - on high pressure fuel pump
11 = Glow Plugs
12 = Glow Plug Relay 1 - engine bay fuse box/relay plate 2
13 = Glow Plug relay 2 - engine bay fuse box/relay plate 2
14 = High Pressure fuel pump
15 = Injectors
16 = Intake air temperature sensor (IAT) - in MAF sensor
17 = Knock Sensor (KS)
18 = Mass Air Flow sensor (MAF)
Feb 04, 2015 | 2004 Kia Sedona
Car will not start
change the fuel pump relay. in engine bay fuse box, also check the other relay in there its for the injectors. if this fails no fuel to the engine.
Mar 09, 2014 | 1994 Cadillac DeVille
2000 mitsubushi eclipse keeps shutting off. Ecu and fuel pump replaced
There may be an oil pressure sensor that is telling the computer that there is no oil pressure. That will shut the car off. Either there is not enugh oil pressure or the sensor is malfunctioning.
Feb 20, 2013 | 2000 Mitsubishi Eclipse
I have a little problem can anyone he lp......... i have a 95 eclipse automatic gs and for som re ason the car keeps shuting off on me. I could be at a st op light or even on the hiighway and it just cuts...
Mine is doing the same .i have changed coil pack,body throttle control sensor, and a idle control sensor. i"m thinking about doing the crankshalft sensor next.
Apr 20, 2012 | 1995 Mitsubishi Eclipse
I have replaced the camshaft sensor, Crankshaft sencor, computer, crankshaft pully, and new spark plugs on my 1999 Mitsubishi Eclipse and it still won't start, what could it be?
Engine needs spark, fuel and air to run. I assume the starter is turning the engine over. Have you verified you have spark at the plugs? Have you verified you have fuel pressure? Can you hear the fuel pump when you first turn the ignition key? If, yes to those, check the timing belt settings to make sure something hasn't caused the timing to change.
Mar 22, 2012 | 1999 Mitsubishi Eclipse
P0340 eclipse
You need to inspect the entire Camshaft Sensor Circuit, right back to the PCM.
Finally, you should also inspect the entire CRANKSHAFT sensor circuit and wiring, right back to the PCM....as Crankshaft circuit failure can sometimes trigger this code.
Nov 12, 2011 | 1995 Mitsubishi Eclipse
Dell GX270 P4 256/40/48X/XPP/NONE (143657523) PC Desktop Logo
35 people viewed this question
Alun Cox
