Question about Logitech Usb To 3.5mm Jack Stereo Headset Audio Adapter
Logitech USB To 3.5mm Jack Stereo Headset Audio Adapter - when I plug it on it says USB Device Not Recognized and i had done already everything. Plugging it on and off. Even plug it off, shut down computer then, taking the battery out and so on what's written in internet but nothing is working for me at all. I need help!
  • 13433 Answers
SOURCE: my logitech usb headset dnt work
your program is probably set to use the wrong input for the mic, check your settings.
Posted on Apr 28, 2008
SOURCE: i cant get my logitech clearchat stereo headset to work for vista
I had the same problem until I noticed I was running Vista SP1. Search and download Vista SP2 and you will be good to go
Posted on Jul 13, 2009
  • 263 Answers
SOURCE: Computer used to recognize my Logitech Clearchat
Try microsoft hotfix..
http://support.microsoft.com/kb/944681
Posted on Aug 02, 2009
therewhite
SOURCE: ClearChat Pro USB headset asks for driver upon install
  1. (Vista) Confirm your system restore point first. It needs to be prior to what you're going to attempt here. If it has a recent restore point, great, but if not, make a system restore before you do this, in case it doesn't work.
  2. In the Control Panel, click System, Advanced System Settings, click System Protection, and click System Restore.
  3. (Optional) Try updating your usb drivers before trying the final step, reinstalling the Vista Service Pack 2.
  4. Here's how to verify if your USB (drivers) in the Device Manager are up to date.
  5. Open the Control Panel, System, Device Manager.
  6. Open the Universal Serial Bus controllers (usually at the bottom of the device list).
  7. Right-click, on your first USB, Updating Driver Software. It will look for the update or let you know (which may take a bit of time) that it is up to date already. Repeat this process on all the USB devices.
  8. If that doesn't work, try this: plug in your headset, and keep it plugged into the usb.
  9. In your Windows Updates, re-install the Service Pack 2. After Vista reboots your computer and finishes the install, unplug your headset from the USB and then replug it in. What you are likely to see is a Windows message indicating that it sees the software and is installing it (minus the windows pop-up message of "where's the driver disc for it?").
  10. Now the trick is to get the headset to play the microphone through the speakers appropriately!
Posted on Oct 21, 2009
neutronrace
  • 66 Answers
SOURCE: Headphone jack of my laptop does not work
You have to set the software in order to connect the wright way. with a USB device it will never work.
go to the properties of your audiocard and theire select what you want
Posted on Feb 13, 2010
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
When i plug in the head phones it say USB device is not recognized.
the plug of your headphone maybe damage....or the wire.
Aug 26, 2010 | Logitech Stereo 350 Headset
Microphone doesn't work with small plug
I'm just taking a stab in the dark here but bare with me on this, I got a lot of info stored in this old head so it takes a while.
If you look at the jack for the microphone, Does it have 2 sleaves and a pin or just 1 sleave and a pin. If it has 2 then you will need an adaptor (Normaly Stereo jack to XLR). If it has 1 sleave then your going to need a preamp.
Apr 20, 2009 | Computers & Internet
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Logitech usb headset A-0374A does not play
probably need to set the Logitech headset as your default device in Control Panel-Sound. XP or Vista updates may reset the audio-video default devices
Nov 19, 2008 | Audio Players & Recorders
I have a durabrand speakerphone ph-3235 and i am looking for a headset for this model
I have a plantronics headset with volume control that i was using for my old cell phone. Now the jack is 1/4 stereo type plug and the duraband speaker phone plug is 1/8. So i went to Radio Shack and got a plug adopter to make it work and it's great.
Here is the specs
(1/4" Stereo Jack to 1/8" Stereo Plug Headphone Adapter pixel.gif Model: 274-366 | Catalog #: 274-366 pixel.gif
This stereo inline audio adapter accepts a 1/4" stereo plug and fits a 1/8" stereo jack.)
Jun 20, 2008 | Lands Phones
Logitech USB Headset
its basic (USB Audio)
browse for the drivers.. or select driver to install
do it from device manager if you dont get a pop up
Apr 16, 2008 | Logitech ClearChat Stereo Headset Headset
Logitech Usb To 3.5mm Jack Stereo Headset Audio Adapter Logo
56 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
