Question about Fellowes C-420C Shredder
Jammed light paper shredder - Fellowes C-420C Shredder
3 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: Fellowes Paper Shredder P70CM paper jam
Clean the upper and lower sensors with a cotton swab moistened with rubbing alcohol.
Posted on Jun 22, 2009
JayBlair
  • 328 Answers
SOURCE: Shredder Jams with more than 1 piece of paper thickness
I have seen paper shreds build up inside the cutter housing on this model. It grows into a big tumor inside and places a lot of resistance. You will have to take it apart and clean it thoroughly. Also, oiling the cutter asm.
Posted on Sep 07, 2009
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
Too much paper into shredder red light on paper is jammed
Some shredders have reverse mode
to eject jam. Otherwise its a slow job - Unplug from mains Remove each piece of paper as close to the jaws of the shredder as possible. Then hopefully when plug in and turn on will not find too much resistance and be able to cope with the paper and drag the jam through until clear.
May 25, 2016 | Shredder Office Equipment & Supplies
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
Red light and green light on but motor will not come on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 13, 2013 | Fellowes PS60-2 Shredder
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
Cuts out after 1 second & red light comes on
The red light typically means either something isn't installed right in the shredder head, or there's a paper jam. Did you recently take the shredder apart? If not, there's probably some jammed paper in there somewhere.
Jul 06, 2010 | Fellowes PS60-2 Shredder
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
Red light on as well as green,what is the red light
The red LED can mean one of two things -- either the shredder head is not assembled correctly (did you take the shredder apart recently?) or there is a paper jam inside the machine. Sometimes the jammed paper is far down and hard to see.
Jan 30, 2010 | Fellowes PS60-2 Shredder
All lights turn on as needed and has power but won't grab paper to shred
suspect paper jam try using reverse button the dislodge paper.
suspect paper feed sensor is blocked or damaged there is a light beem in front of the teeth that starts the shredder if this defective the shredder will not start.
suspect a panel or bin is not correctly seated causing the shredder to not start.
Nov 13, 2009 | Fellowes Powershred 320C Shredder
Fellowes C-420C Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
