Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Need to replace spindle bearings on Husqvarna yth1848xp mower deck
  • 6 Answers
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Posted on Apr 22, 2009
dnewcombe1
  • 1564 Answers
SOURCE: HUSQVARNA-YTH1848XP riding mower with loose front right wheel.
Of course they are. The company sent you the wrong bearings.
Posted on Aug 22, 2009
tunde007
  • 2382 Answers
SOURCE: I aqm having difficulty with
Hi, it sounds like the something is wrong with the electric clutch. It has a brake built into it that is supposed to stop the blades when the clutch is disengaged.
The clutch has a rotor attached to the engine shaft. The coil is inside the rotor toward the engine. There's a clutch disc attached by leaf springs to the pulley for the belt that drives the blades. There's a brake ring around the disc. When the clutch is engaged, the disc moves away from the brake ring and is held tight to the rotor.
Posted on Apr 11, 2011
ftw1952
  • 10319 Answers
SOURCE: My 54" Husqvarna L&G tractor
the internal clutch has gave out. On the Honda brands the clutch plate can be reversed to repair this situation if happening. On yours I have no idea if that will work for I never had one of these apart before
Posted on Apr 30, 2011
  • 910 Answers
SOURCE: YTH 180 46" mower deck
There aren't any after market decks for this but it does appear that the original part has been superseded by a replacement so maybe this has solved the problem (see link below).
http://www.superxpower.com/pages/OemParts#/Husqvarna_Power_Equipment/YTH_180_(954140010B)_(1996-12)/Mower_Deck/4018040005/18040031
although you could get cheaper and maybe worth a quick search to compare prices.
http://www.mowpart.com/advanced_search_result.php?keywords=532176026&osCsid=t2du52sd4fgtb5gqm834f3hbg0
Posted on Jun 12, 2011
How to replace the spindle on a 48 inch mower deck
OK, Now I see your question under a different post. You are going to have to pull the deck out from under the spindle housing and spindle and replace them. They usually come as an assembly. after removing teh deck you should see the spindle housing retaining bolts to remove. Make sure you pull the blade off that spindle before you try removing it.
Oct 02, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Yth1848xp bogs down at full throttle when engaging the mower
Carburetor could possibly need cleaning or rebuild, Governor linkage could be dirty and not operating freely, or it could be out of adjustment
Sep 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need a blade spindel for my husqvarna ZTR DOES IT COME TOTALLY ASSEMBELED and one new blade model #968999155
Hi , Wow glad I don't own one of these The spindle completely assembled is part 539104403- 138.37 or bearings #539102677- 67.59 or shaft 539104402- 33.14 all available at
/www.sepw.com/ hope this helps.
Jul 18, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Husqvarna YTH1848XP Riding Mover stalls with throttle increase.
Check your Vacuum line going into the back of your air intake box.
Jul 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mowes unevenly. Blades don't match up.
make sure when you replaced the spindles that you used all the washers and spacer bushings back identical to the ones you took off.
Make sure your deck isnt bent for some reason where the spindles mount and or the deck itself
level the deck when its on the mower on a level suface,side to side(level) back to front the back just a little higher than the front 3/8 inch or less
proper air pressure in all 4 tires
Also you could add a washer or take away a waher to allow the blades to become level at mid point meeting?
be sure to torque the blade bolts to 35 ft.lbs also
May 31, 2009 | Husqvarna Garden
Repair manual My husq will run and go into gear but will not engage the deck all belts are tught contact me at everette_pettus@yahoo.com
If the deck drive belt tightens but the blades don't spin it is because the spindle bearings have frozen. This usually happens with age and is made far worse from storing the machine outside.
If you have the technical ability, remove the cover over the belts on the deck, and see if you can spin each pulley. They should spin rather easily. If they don't, replace the top and bottom bearings in each offending spindle. If you don't have the know-how, bring the machine in for repair.
Apr 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
12 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
