Question about Dell OPTIPLEX 745 PC Desktop
Unlock keyboard lock by scam
  • Jonathon Saeed Mirza Dec 12, 2013
    Hi eddie , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    What type of lock, Digital, Electronic, Mechanical, Software or Key
My imei is 862990011189890 pls. send it to me my unlock code.
It don't work like that. If your phone is locked to a carrier you have to go to that carrier and request they unlock it for you(different carriers have different stipulations on if they will unlock a phone or not, so you gotta check with them) or pay a site to unlock your phone (again, most sites will only unlock your phone if the account associated with the phone is paid, in good standing, and generally out of contract, and also not black listed (reported stolen)). Generally you are wasting your money doing it that way because most of those sites require the same things the carrier require to unlock the device, but some can do blacklisted phones and other unlocks, but some may also be scams and it's not easy to tell which are legit and which are scams. Best bet would be go through your carrier (or carrier that the phone is locked to, if it's not your carrier).
Jun 07, 2015 | Cell Phones
How do I unlock the keyboard
Wired keyboard usually do not have locks, However some wireless keyboard do. A switch is usually on the top side of the keyboard that slides back and forth.
However you may also be seeing "Caps Lock" which means the Caps lock key is engaged. Simply press the "Caps Lock" key again to unlock it. The caps lock key is located at the left side of the keyboard.
Dec 12, 2014 | Microsoft Wired Keyboard 600
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
How to unlock the scroll lock key
Hi!
To unlock the scroll lock key on your zippy keyboard, please press the scroll lock key again.
Every time you press this key it switches between lock/unlock.
Regards,
Aug 20, 2011 | Zippy EL-610 (840556027058) Keyboard
What's the best way to unlock a Caps Lock key that won't unlock by simply pusing the Caps Lock key to unlock it?
goto start > run > type "osk" and click ok...
On-screen keyboard will be displayed...
select keyboard in the menu bar... select 102 keys...
Use the Lock key in the on-screen keyboard... it will turn OFF/ON the CAPS lock
Jan 15, 2011 | Microsoft Computers & Internet
How do you unlock the CAPS lock
To unlock the caps lock on your keyboard, please click on the caps lock key again.
Check for few iluminating lights on your keyboard as well, as few of the models does have that.
If the Caps lock is ON the lights normally illuminate and If you click on the caps lock key again, the lights go off.
Feb 07, 2010 | Gateway 2520915 Keyboard
Unlocking Codes
try online at mobile2mobile.net or unlockitnow.com
Dec 24, 2008 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Unlock keyboard
I have an Olympia ES95i and if you hit code on-line it locks the keyboard. To unlock, press code + online then code + clear. Hope this helps
Apr 16, 2007 | Olympia Monica 2 Typewriter
Dell OPTIPLEX 745 PC Desktop Logo
Alun Cox
